Better photo of the vent hose relocation. It’s not so muddy looking with natural light
I tried installing my steering box brace, but when the brace is bolted, the steering shaft doesn’t line up in the center of the hole where it should. Either they didn’t make the slots long enough (I could shift the brace over slightly if I had more play) or someone messed up and put the plate too far over when they welded it on.
I don’t have a welder big enough for that metal thickness so it’s either pay someone to weld the plate once I grind it off and move it, then paint the fresh metal OR take a dremel with a grinding stone and make the slots for the bolts slightly longer so that I can shift it over some to line everything up. I haven’t decided what the best option is. Either way, I’ll spend money because I’ll have to atleast buy a dremel since I don’t own one. [emoji849]
Next weekend I will try to find time and install my rear extended brake hose. I picked up more fluid today so I can bleed the brakes once it’s installed. I will also hopefully be tackling my transfer case seal. Picked up almost $30 worth of synthetic fluid for it today. Also going to go ahead and order lift shackles for the rear and go up 1” or 2” more on it.
Looked at the house today that we want, but it’s gonna need a roof so we have to get some estimates and I need to finish bank approval. The megacab is going to be putting in some work hopefully soon. When we move, I’ll be pulling a tandem axle trailer with the large/heavy stuff and I’ll stack my bed sky high. Trying to move in only 2 trips (it’s about 35+ miles from where we live. Moving to the sticks)
