Yes, ANOTHER Fender Flare Install Thread
Odin
Arizona aka HELL
Hemi 6.4L
Well hello my fellow brethren of the RAM!! Let me share with you a tale of install, cursing, and copenhagen...
For this install you will need the following:
Some RAM 2500 OEM Style Fender Flares (made in China I'm sure). These were like $155.00 shipped. Two different listings; one for texture and one for smooth. You'll have to search for smooth as I chose and like the textured version.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/272519955737
1 can of Copenhagen (your flavor, mine is Natural Extra Long Cut)
Socket wrench with a 5/16 socket and a 3/8 torx screw bit
5/16 drill bit and drill
Toothpicks and tweezers
Acetone (and rags)
Heat gun (optional, explained later)
Simple math skills
Common sense
Patience
Let's begin, this will not be a picture heavy thread. More so my thoughts on install and review with some pics of before and after.
Depending on what condition the exterior of your truck is, make sure at least 4" of your fender is clean all the way around where the flare will be installed. Wipe it fine with acetone to remove any oils or stuck on tire goop which gets thrown up after tires get wet.
Once done you wanna hold the flare up and check for fitment. Mine did not come with predrilled holes, rather they had little marks where the factory screws attach. The rear on this set were missing 2 factory screw locations near the top middle of the fender so I had to mark and drill those. The front were missing 1 factory screw location near the bottom towards the cab of the truck. Hence the basic mathematics being counting.
When checking for fitment make sure to adjust for any marked areas which don't line up properly and drill all the holes.
The first flare I installed, drivers side front, was slightly off even after drilling the holes, not overly noticeable to anyone else but myself.
For the front flares I suggest securing the flare near the cab with the first 3 screws. Pull the flare away from near the front and remove a small section (roughly 2") of the 3M tape film to reveal the tape; this is where the toothpicks and tweezers came into play. This will allow you to make any adjustments you need while installing. Make sure the 2" of film is sticking out between the flare and the body.
Next, secure the front of the flare to the fender but don't tighten the screws down to fully tight or you might not be able to get the 3M film off.
Then, remove the 3 previous tightened screws near the cab and repeat the process you did on the front.
After all screws are tightened to snug, remove the 3M film and tighten the screws the rest of the way. Rub all the exterior of the flare with firm pressure to secure the 3M tape to the fender.
For the back, you'll need to remove whatever the little plastic piece is near the lower rear quarter panel. This is where you will need the 3/16 torx bit. My screws wouldn't come out all the way, luckily they are just plastic, so I ripped them out.
Repeat the same process for install on the rear as you did on the front. Again, make sure you count how many screws there are. I didn't realize there were more on the back so first rear flare I installed I had to remove two more screws and drill two more holes during the install which I hadn't noticed when doing prefitment. The flares come with an addition plug to use on the rear fenders to snug them up more at the top. I suggest they be used.
Once all of the flares were installed is where the heat gun came into play. Depending on your weather, I live in AZ and thought the weather would cooperate but it didn't... Very cold outside compared to recent days. I chose to take the heat gun and on medium heat ran over the flare where the 3M tape is for several passes while rubbing with a rag to help with adhesion.
Curse words flew out here and there but not as many as I was expecting. The whole thing start to finished too about 2 1/2 hours due to readjustment, drilling holes, etc. I had to move the truck in and out of the garage also the sky was rather dark with rain clouds.
Pre install
5a424f86d56f4dce4c59e57e6e5b70f9.jpg14766a58fc9d3ee85ba3d11080ca2dbe.jpg862f79d96a712d188030fa3ee93e053b.jpg5a323c326b03e3aa2b42479dac62b50d.jpg1038485765c345ce759f62377a776d33.jpg0ddae68f471faa89bc013e690bb8dcbd.jpg557ad399d34738ccb667c84e290e4ee9.jpg932f573ce56fd19cfa785167716dc29c.jpge4d2dec1046a468b7585ffc2762d4ccf.jpg
Odin
Odin
Arizona aka HELL
Hemi 6.4L
Overall, I'm extremely happy with fitment and quality. I couldn't justify paying the $400+ for OEM Mopar fenders when these in my opinion are just as good.
stimpy433
IOWA
Looks good!!! What offset are your wheels and tire size???
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
well done and thanks for detailing so well in your write-up. Definitely gonna help the next dude. But where in your method of procedure do you list BEEEEER? :cheers:
Odin
Odin
Arizona aka HELL
Hemi 6.4L
Lol. Its gym day after doing the install... Beer had to wait till now.
Odin
Odin
Arizona aka HELL
Hemi 6.4L
Next to go are gonna be those nasty chrome bumpers so it's got all black going on. In the process now of finding different facebar and rear bumper. Also seeing how much it would be to de-chrome both and powder coat them with a satin textured black.
Dbjb
NorCal
Hemi 5.7, Sport 2wd
Well done sir! I just got my wheels and they seem to protrude the same as yours. Will get some flares now to add a little paint protection.
Truck looks great!
Odin
Odin
Arizona aka HELL
Hemi 6.4L
I don't remember the offset to be honest but the discount website is saying - 19?? Not sure if that's correct. Tire size is 325/65/r18.
Odin
Odin
Arizona aka HELL
Hemi 6.4L
Truck looks great!
You have a 2500 also? Or 1500?
2010 Infantry Vet
Butler pennsylvania
First thing I didnt like on my ram when i got it was the chrome bumpers. I replaced my front with a painted one piece plastic, now need to replace the ugly rear chrome bumper with a painted dual exhaust one.
Your color would look badass all the same color. What made ya decide on flat black on the bumpers?
Odin
Odin
Arizona aka HELL
Hemi 6.4L
First thing I didnt like on my ram when i got it was the chrome bumpers. I replaced my front wirh a painted one piece plastic, now need to replace the ugly rear chrome bumper with a painted dual exhaust one.
Your color will look badass all colormatched!
Not color matching. I'm doing a triple color theme. Blue/Black/Red.
The front and rear bumper are going to get replaced with a powder coated textured satin black and I'll be doing a black and red vinyl on the hood. Basically the same one that comes on the Power Wagon but much larger, it'll cover the louvers. Trying to decide if I wanna line-x the rocker panels with a medium texture satin black to tie the whole bottom portion of the truck together. I've already got a bunch of paint chips down to metal on the rocker panels so it needs something.
I'm in the process of also having custom painted badges. So think of the current badges I have, but RAM flame red around the edges (got the idea from my wife's Trailhawk).
JB1
Houston, Texas
I hope you follow thru with this plan, really sounds nice
Odin
Odin
Arizona aka HELL
Hemi 6.4L
Got my vote for the Line-X on the rockers. Cant wait to see it all finished
Thanks guys. Gotta find a good place for vinyl here in AZ and same goes for powder coat. I've got some emails out to a few places, waiting on replies with pricing
2010 Infantry Vet
Butler pennsylvania
Get ahold of this guy. http://vellosvinyl.com/
He supports combat vets. He will make you what ever you want. Made all of my white subdued american flags for my jeep.
He is a mom and pop type of shop, and therefore will do any color, size, or alteration you want. 1/3 of everyone else.
Crazy cheap, and super easy to work with.
Odin
Odin
Arizona aka HELL
Hemi 6.4L
Hell yeah!!! I'll do that for sure! Thanks man!
You know him personally?
2010 Infantry Vet
Butler pennsylvania
Yea i do. Hes a good dude. And will custom make any shape, size, of color you want. He developed my white subdued american flag on his own. I was blown away when i saw it. Ended getting one on each side of the jeep as well. I literally just messaged him to make one for my hood, and back window.
