2014 Ram 1500 w/ Projector Headlights OEM... Headlamp connector pigtail
DARKNHT
Georgetown, IL
Is this avail? I my lock tab is broken on the LH side. I’d like the LH, and RH side.
I looked on the site and couldn’t see it in the catalog.
Again I’m after the body side connector that plugs into the headlamp assembly that has 14 terminals on it (although not all used). In a pigtail fashion with leads.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Reach out to Jeremy at RetroShop, he likely has the parts (or at least PN's for pins/connector housing) and may be able to make you up a pigtail to repair it if you don't just get the connector asaembies and swap the pins over.
DARKNHT
DARKNHT
Georgetown, IL
Thanks!
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Connector pigtails are available, Is the connector a 3 pin or 14 pin?
-Benny
