So amongst all the excitement and trying to get this all done, I think I may have misunderstood some things. Hope someone could clarify. So as I understood, I could take this LC7i amd hook up amps through it with the stock radio. I now understand its function clearly. Where I am confused now is this. I have "tapped" (hoping the definition of that termbis not the problem) the front and rear speakers. By that I mean this, I used speaker wire taps. For the fronts Inoulled the head unit, and tapped in there,then running new wire from there to the back of the truck to the LC7i. So the stock connection to the actual speakers is still there. Then for the rears I tapped each side at the B pillar, running new cable from that point to the LC7i.
I now have them all plugged into the LC7i. The fronts are plugged into the main input and the rears are plugged into Channel 2. When I turn on the car the power light on the LC7i goes on, and that is the only light that turns on. I'm assuming the lights that say " connected to main channel" should light up if it is working correctly. Also I have tried using an AC-ALG. I also bought some resistors that AudioControl recommended but still no joy. The speakeks all work, but seamingly not as they should.
My main question is, is the method I did of "tapping" in correct?
Also, I measured the voltage on the speakers plugged into the LC7i and they are showing about 6 volts.
