What did you do to your Gen3 today?
bulrid8
Oh yeah nice quiet town I love it friendly people
My BIL owns south eastern machinery. If you ever need welding or something made. They are really good.
Neurotix82
Spring Hill, TN
Hemi 5.7 (345)
you said you had the rear end replaced, what gears are you running, you can always try some different gears for some more torque, i know a lot of performance guys running 4.56 gears, my 3/4 ton HD is low geared as hell and while it runs some high RPMs at higher speeds, it is a torque monster...
4.56 seems to be a pretty popular choice. I've had a few people recommended. I'm assuming my guy went stock, though. It's a new assembly from Jasper is all I was really told about it.
My spider gear had busted teeth. Apparently the manufacturers went from using shims to a procedure where it's heated, built, then shrinks when cooled.. and that seems to me like more room for error as I've been told this model is notorious for rear end trouble. I was recommended swapping out the assembly that uses clips for something like Detroit locker, as well.
It's worked perfectly for the last 100k miles, but the last diff fluid change I noticed there may be a little wear going on.. which worries me. The more wear that takes place, the more rapidly it will continue to wear until it starts busting teeth again.
I think I may go for a 4.56 ratio when it gets closer to time for rebuilding maybe.
Another thing I noticed, and I may be mistaken, is that there is no housing (bearing) to help support the driveshaft. Not positive if my model has or can have it, but I can't imagine with such length why it wouldn't to help prevent wear or play at the ujoint.. or spindle wear at the transmission?
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
Today I spent about 4 hours sanding my headlights down and re-applying a clearcoat onto them, the lenses are a bit fuzzy but definitely MUCH better than they were before
Also while I was at it, I replaced the washers and bolts holding my tailgate spoiler in place. 2 of the washers had already rusted off, and 1 washer had warped around the screw due to heat. I'm trying to decide if I like the look of the more noticeable chrome bolts I had to buy because of AutoZone's very limited selection of bolts
I would've cropped these to be smaller but I'm clueless as to how lol
02ramboi
live oak florida
4.7 v8
Very clean single cab you have there and to me bolts don’t look to bad
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
nice truck, its headed in the right direction, on the headlights, wet sand them with 2000 grit sandpaper and then polish them, that will help take away the haze, ill assume you used a rattle can clear coat huh?
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
The pictures definitely helped me hide the dirt :D I cleaned it saturday night, then about midnight that night I had to fly over to a friends house quickly due to an emergency, so it has about as much dust as would be expected when you're driving 70 mph down dirt roads (definitely not a good idea lol) and i guess while I was out there some bird decided to take a dump next to the drivers side taillight. Not exactly a good day lmao. The bolts I think are growing on me, or maybe I'm just to lazy to do something about it, i guess we'll never know lol
Thank yah, and yeah I used that rustoleum spray-on clearcoat paint stuff, hopefully it will stay on better than the clearcoat that was peeling on me 3 months after I bought the lights. Anyways I might hit it with the sandpaper and a polish today since it's at least not 90 degrees with the sun beating down
In other news, I hit 129k today
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
now I need to r/r the windshield washer switch/signal.........might give a junkyard a call
Demon-HeMi
Houston
to be honest you could actually just sand and polish the headlights and never have to worry about clearing them, just keep em waxed and they wont yellow
thats what i did to the headlights im currently running...
My before
After wet sanding and polishing, no clear coat sprayed
Demon-HeMi
Houston
Switched from white to warm white LED interior lights...
Virtually the same exact color as halogen, i love it
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
My before
That looks great! Thats exactly where my clearcoat was peeling off
What did you use to polish them if you don't mind me asking?
Demon-HeMi
Houston
For that, i use professional polishes, but for something like that the $20 polisher and some mothers polishing compound would do similar results
rocket
connecticut
was 2006
was a HEMI 5.7
least I don't have to feel my insides cringe when I hit the brakes these days
