Bama1781
I have a rear spring question. on my 17 4x4 1500 I have a RC leveling kit installed on the front but when I put some HVAC stuff in my bed sometimes depending on the size etc I get rear squat. So I was looking to replace the rear spring with some HD springs that might also raise the Rear up a little. Ive seen the tufftruck springs and asked them about how much there rear HD springs would raise the rear up if any unloaded I don't mind a slight rake. the other option is the super springs which are almost double the cost and I know will raise the truck up 3/4 of an inch in the rear . So since tufftuck wont return my emails my question is anyone running tuffstuck springs how much did it raise the rear and if not could I run a rear spacer with them.
