dodge ram
  1. M
    Need Help Identifying MOPAR Shock Absorbers for Dodge RAM
    Hello, I have some MOPAR shock absorbers for Dodge RAM trucks and I would appreciate your help in determining which model each one is for. The part numbers are: 68374980AD 68417124AC 68349129AB 68379493AB 68349199AB Thank you very much in advance for your support!
  2. Off-Road Control
    Dodge RAM 1500 5.7 Hemi vs UAZ [MUD OFF Road]
    https://youtu.be/UhIDNHfAZ4s Dodge RAM 1500 5.7 Hemi vs UAZ [MUD OFF Road] Hello, went off-road with friends in search of adventure. Many interesting cars took part in this event. Standard unprepared Dodge Ram 1500 5.7 Hemi Big Horn, two UAZ with large 36 inch tractor wheels with axles from...
  3. Jessman22
    2018 Dodge Ram Upgrading from 5.0" Uconnect to 8.4"
    i had recently picked up the 8.4" screen with the plastics you see in the picture was just wondering what else I would need to complete the set up from the videos I've been watching looks like I need a wire harness and a heater control module but not sure,, The 2nd picture seems like that's the...
  4. Off-Road Control
    DODGE RAM 1500 vs UAZ vs ZAZ Monster. Stuck ALL [MUD OFF Road]
    Vehicle characteristics: - Dodge Ram 1500 Big Horn: 5.7 HEMI automatic transmission 34.4” BFGoodrich All Terrain - UAZ 469: 2.5 Mechanical transmission 36” Tractor wheels FBel-160 - ZAZ 968M Monster / Zaporozhets: 2.5 ZMZ-405 manual transmission Axles / Suspension from UAZ 33" Forward Safari...
  5. Tentoesp
    Leak and noise from L front diff
    I have been hearing a noise coming from the driver's side wheel only when making right hand turns. The noise is repetitive with each rotation of the wheel. Today after work I looked and saw there was traces of diff fluid on top of the knuckle, where the u joint and axel meet. (May be...
  6. T
    Dodge Ram 2500 1994
    Hey I want buy Dodge Ram 2500 1994 Engine: 3.9L V6 SMPI Engine (EHC) - Gasoline I want to know if the engine is reliable? And what its problems are? Is the engine powerful?
  7. D
    Has anyone ever swapped an NV3500 behind a 318?
    My 46re tranny quit on me today. It's been acting up for a few weeks and finally died. I'm thinking about doing a 5 speed swap now that I have the opportunity, and have found an NV3500 with transfer case out of a '95 chevy pickup available for $500. Just curious if anyone has swapped one behind...
  8. L
    O2 sensors on 2015 1500 Hemi 5.7 V8
    Hello! I have a question on O2 sensors. Does anyone know how many sensors this truck has? It's 2015 1500 Ram Hemi 5.7 L V8. I was doing some research and was thinking 4 (2 upstream, 2 downstream) but I cannot find anything concrete. Our truck is in the shop because the check engine light keeps...
  9. Y
    Need help with installing 2013 seats into a 2011
    Needing help on the wires that I need to gain power from so I can work the lumbar and back and forth function ? Any help much appreciated
  10. J
    LED Lights Acting Up
    I have a 2002 Ram 1500 and I decided to do some lighting upgrades and throw in some LEDs. There is just one thing that bothers me though. After the truck has been sitting for a little bit, I open the door and every led light on it blinks, even if they have a load resistor on them. Was just...
  11. 1ATony
    2010 Dodge Ram 2500 Truck Power, Heated, Turn Signal Memory, Puddle Light Towing Mirror Set
    Great prices and free shipping: 2010 Dodge Ram 2500 Truck Power Heated Turn Signal Memory Puddle Light Manual-Folding Chrome Flip-Up Towing Mirror Set
  12. S
    Help 2014 front Differntial
    Ok Team, Here is what I have: 2014 Dodge Ram Express, Club Cab, 4X4 Hemi 5.7. Problem: Front CV joint failed on (Passengers Side) damaging the differential stub shaft (App 10” Long) Ordered new CV from Dodge, went to change it out and noticed the stub shaft end was all worn away. Looks like...
  13. R
    Does this look correct?
    5.9 360 at TDC, is this the correct rotor position?
  14. R
    Truck dies at initial start
    i recently swapped a 5.9l 360 in place of my factory 5.2l I installed a comp cams “RV” cam shaft installed new coil, plugs, wires, distributer cap and rotor, crank position sensor, as well as various other sensors... I got a 5.9l ecu from a local pull apart yard as i had read on other fourms...
  15. MusicMan14
    Increase 5.7 Hemi gas mileage
    I have a 2003 dodge ram 1500 with a 5.7 Hemi and I am looking for every possible way to increase gas mileage because I am spending way too much money on gas but I know some people will say to sell it and get a different truck that has better gas mileage but its not that easy because it was my...
  16. F
    Suspension between generations
    Out of curiosity, how much did the front suspension change on the 2wd, between the generations?
  17. F
    03 dodge ram 5.7 hemi
    Ok guys needing some help, my 03 ram 5.7hemi is having some problems and I'm done chasing possibilities. Ok so problem- #1-after 40mph my truck has no get up and go you can push on the pedal and it has nothing it takes awhile to speed up. I changed the plugs the oil I had a cold air intake put...
  18. M
    Please help 05 dodge ram 5.7 hemi rough idle
    My truck recently started idleing really rough I'll crank it and the revs will go up and down between 4-9 hundred rpm and lights will flicker.I'll give it some gas and it'll stop idleing rough until I let off then usually it will die and start smelling like gas. I've replace the egr valve and...
  19. Boosted Motorsports
    The COMPLETE Shorty Header Installation Guide - DIY
    I finally had a chance to edit hours of footage of the JBA Shorty header install for the 4th gen RAM. Overall the job isn't difficult it is just labor intensive and takes a bit more time and finesse getting at the manifold bolts. Definitely check out this video if you are considering tackling...
  20. R
    2007 Ram - Whining Noise
    Hey all, I just replaced the alternator on my 07 Ram, 5.7. After replacing the alternator, my truck in now making a whining noise, it almost sounds like a turbo. The noise is coming from the alternator area and is mostly heard at idol or very low speeds. The noise was not there before I replaced...
  21. Johnathan Lower
    Total remodel of 2014 Express. Looking for interior parts.
    I have totally redone my 2014 Express. Putting a new Tesla like 10.4 inch screen in the dash, was previously a bench seat but swapped the bench console for the full console to dash floor console, new factory leather seats i found, relocated gear shift from column to console, new limited...
