So I was heading home from work and the radio suddenly cut off. Tapped it a few times and nothing. Started playing around and found that my satélite radio worked, just not my fm/am. Didn’t think much of it, looked some stuff up and thought it to be a fuse. Got home and checked my fuses and they...
New here and needing help with my 2017 1500 Big Horn 3.6L.
Engine is overheating and I'm getting a P0480 error saying the Cooling Fan 1 Control Circuit is failing. Went to check fuses/relays but they're missing from the fuse box. Never had any issues before so I'm not sure if it came that...
Help. I blew the charging port on my dashboard, the old "cigarette lighter" type port. Should not have put a portable inflator in there! The owners manual is useless as to what fuse this is. I located the fuse box next to the battery and popped it open. Too many fuses to determine which...
I have a motorcycle and just got off the phone with a super smart ECU flash guy.
Somehow got sidetracked and started talking about the Hemi and he said something I haven't heard or read before, so figured I'll post here see what you guys think on the subject.
He said how when you first...
Hi,
I've come to the conclusion that my '03 3500 diesel truck needs a replacement Power Distribution Centre / fusebox.
Part No.68005474AB
Does anyone know of a good place to buy one for a good price?
My local Dodge dealer has quoted C$957!
Many online stores won't ship to Canada, so I'm a...
Hi,
I have an '03 Ram 3500 diesel (standard trans.) and suspect I need to change the Power Distribution Centre, due to misbehaving lights.
I believe my current PDC is Part No.
68005474AB.
It costs C$957 from Dodge..!
If I go looking at the scrap yard / auto wreckers, which year models'...
I have a 2011 Dodge Ram 1500 4.7L. About two nights ago I opened my truck door and noticed that the dome lights did not turn on when the door opened. Once I started my truck up I then noticed that my Traction control or the Tow/haul button also did not do anything when pressed or light up at...
I have a 2018 Ram 1500 5.7 Hemi and used to have halogen lights. I replaced my Headlights and Foglights with OPT7 fluxbeams. Also had OPT7 on my 2016 Ram for 2 years and never had this issue. Around Christmas i noticed my passenger Headlight and passenger Foglight went out at the same time. I...
Not sure what happened to start this. I have a 2008 1500 4x4. The cigar lighter on the driver side has never worked since I have had the truck. I used a small 12v air compressor to top off my tires using the dash cigarette lighter on the passenger side, all worked fine.
I hopped in and...
I have a 2012 Dodge Ram 1500 with the 4.7L 8 cylinder engine that seems to have some sort of electrical issue. When I turn the key to on or start the truck, there is no response from the car but if you wait there for a few minutes with the key in the ignition, power comes to the dash and will...
Is there only the one fuse box under the hood? None inside the cabin anywhere on the 2018's?
I have a dash camera I used to have hardwired in another car with piggyback fuse as well as a security system. If there's no fuse box in the cabin, I guess both of those options are null and void now as...
Hey guys first post here on ram forum. I had an issue w my 2008 1500 where the right cigar lighter worked fine and the left didn't (phone charge/FM->Bluetooth thing, etc.), Cigarette plug w the icon printed didn't work on either. Right showed 12.4 volts, left showed .2. You'd think a blown fuse...
Hello to all. I am new to the forum so I apologize if my questions are redundant to you. 3 yrs. ago I bought a 2005 QC w/5.7L. Was unaware of the fuse box/pcm issues with these trucks at the time. The only symptom I have is the wipers seem to have a mind of their own on inter. mode. May not be...
