Hi I’ve got a 16 express most basic package nothing cool about it what so ever I wanna slowly turn it into little pieces of every package I like and want first off does anyone have parts for the 8.4 with maps apple car play etc that will work for conversion they don’t want or I can buy? I will...
(2020 Ram 1500 Classic Express) I swapped the base gauge cluster for the EVIC 7-inch cluster a couple weeks ago. Finally got around to correcting the odometer yesterday. Everything is working as normal after this correction except for the fuel range display, which is now stuck at 1999km (I'm...
I'm trying to replace my gauge cluster on my 2001 3500 diesel. Dodge no longer makes the part so the dealer sent it out to be fixed - $735 later I get it back and the gauges all work now but the back lights don't come on so I can't see the gauges at night. $365 later the lights worked roughly...
So I just did the tachometer fix where you resolder two of the circuit boards, and it fixed the tachometer (it used to be 500-100 rpm off). Now I’m having an issue with the backlighting on the gauges and I’m wondering what I messed up. It seems that half of the backlights still work, and half...
Selling some spare parts I have that we’re removed from a 2016 Ram 1500 with 33k miles.
Steering wheel bezel with buttons, I bought a spare to use to customize and body match paint to my truck . This is the original out of my truck. $100 (lowered to $65!!!) including shipping in the US
Gauge...
I have a 2010 1500 Hemi 4x4 Big Horn. Is there any way to replace the gauge cluster with a 2013 pr newer gauge cluster with the 7" screen in the middle. Also is there any way to replace the dash with the newer bezels and radio. Basically completely update the entire front dash and everything...
pin 4 at the headlight switch or/br is the 12v supply to light your gauges installed
pop the dash side panel off and unplug the headlight switch and pull it out to work with..........careful the steel framing of the dash is SHARP!
made this thread because the search function doesnt cut/dry...
I've researched this a little online, and seen similar issues on other Dodge Rams and other brand (i.e. Ford) trucks: my Odometer light on my instrument cluster fades in/out, and has been getting progressively worse. Its to the point where the Odometer light on my cluster is out for a week or...
Upper Glove Box Kit (Used), includes:
- diesel grey upper glove box door
- bin with light
- mounting hardware and latch
5DB55285-EC07-4838-87D8-D0EFADBF286C by Moparman16 posted Sep 24, 2019 at 12:02 PM1F2CAABC-12E7-4953-8183-72504F8430E0 by Moparman16 posted Sep 24, 2019 at 12:02...
Truck starts perfect in the morning, Starts perfect after work (sits 8hrs). After
work (or even just regular trips from home) if i go anywhere IE: grocery store / home depot and come back to start my truck it
intermittently wont fire up. Everything works except the battery gauge is to
the far...
Been looking for a list of bulbs needed for swapping to LED... I find lots of examples of before/after but no details of what was needed.
I went to superbrightleds as mentioned by many of the people who did the swap, but the site doesn't list the cluster/dash bulbs. It does list a luggage...
Every few days i'll get in the truck to to take off and i go to put it in reverse and the square for PRND21 is not highlighting which gear he truck is in, has no pull at all hardly. does it through all the gears. shut the engine of and fire it back up the indicator is back. i have an 03 neon...
