how to
  1. Waterfowler41
    How to: Install Core 4x4 Rear Lower Control Arms
    The following is a quick walk-through of how to install Core4x4 lower control arms. Even if you are just replacing like for like, this walk through will apply. I installed some fixed length lower control arms on my 2020 Ram Rebel the other day. These will beef up the rear suspension and...
  2. Motor Head
    Door Speaker Replacement for Crew Cab
    Whatsup gents, above is a video I made about replacing your factory cheap speakers for the rear doors on any 4th gen crew cabs. The principle is the same for the front doors as well. For those who have done the upgrade, I know it may be simple although for those who haven't, it serves as a...
  3. Motor Head
    2013-2018 How-To Install Thuren/Carli Coil Leveling Kit w/Video
    As mentioned earlier, I have made a tutorial of how I installed my thuren 2" leveling coil kit with their overland shocks. This is how I did it, a technique, and was a successful install. Let me know if yall have any questions!
  4. Motor Head
    Rear Differential Fluid Change (AAM 11.5)
    For those who are looking to get their rear differential fluid changed out, here is my tutorial video I made of the process I used. Overall, very simple process, with minimal amount of tools. I threw in Mobil 1 75W-90 to suffice, until I can throw in some amsoil for the long haul. After draining...
  5. Motor Head
    Rear Shock Replacement How-To w/Video
    As we all know, driving unloaded can mean a bumpy ride especially if your like me and am annoyed if my TPMS is always telling me to fill the rear tires to 80 psi. Since that's so much of a pain I keep my rear's at 70psi, which still creates a harsh ride. I figured I would replace the rear shocks...
  6. Boosted Motorsports
    How to Swap Grille Inserts
    Made a DIY video on how to swap out the grille inserts on a 4th gen. Takes a bit of patience but if you follow the tips in the video its actually pretty easy!
  7. Boosted Motorsports
    How to INSTALL LED Bed Rail Lighting on Your Truck
    In this video I review how to install LED bed lighting on your truck! This is a step by step do it yourself video for those that want to tackle it on their own and shows what is involved. With some patience and some simple planning you can wire and rig up your truck to have led lights in the...
