dudeman2009
- Feb 9, 2016
- 1,562
- 208
- Location
- Arizona
- 2001 1500 Sport with enough electrical modifications to make my brain hurt
- Magnum 360
Two things, the T for the oil pressure, pretty sure its just 1/4in npt thread, it might be 3/8ths, but its not flared or metric.
As for the PTO wire, I did a bunch of research and testing with it last fall because I was looking into a high idle switch to run some accessories.
The PTO wire does nothing more that I can find definitively than tell the computer to ignore certain conditions that indicate an operating failure, so the check engine light doesn't illuminate when using the PTO.
It does nothing more than that.
Unconfirmed is on vehicles equipped with a PTO (It may be a programmed function of the Cummins engine controller) that hitting the steering wheel mounted cruise control switches will adjust the idle speed in 100RPM increments. Though I cannot test this as I do not have a diesel.
I have tried through experimentation activating the PTO wire and trying to change the RPM with the cruise control switches to no effect. I am able to confirm that certain ABS and vehicle speed sensor codes do not trigger with the PTO wire enabled.
