04 trans problems need help asap
fireandice
545rfe transmission will do absolutely nothing no forward gears no reverse gears I was driving down the road no slippage no jerks no nothing and then just felt like it went to neutral fluid level was fine at the time no engine codesbesides a speed sensor drop the pan change filter new fluid still nothing it does make a weird noise after you shut off the engine for a couple seconds any help would be great
tpbarnzy
I have the same problem, going to do filter and fluid change also. I got codes on my tuner, P0933, P0868, P0869, 1st hydraulic pressure sensor, 2nd+ 3rd low and high pressure. Going to try pressure sensor also.
