07 1500 4x4 with 35s?
Discussion in 'Lifted' started by Snipes318, Jan 4, 2017.
  1. Snipes318
    Snipes318 Junior Member
    Jan 4, 2017
    Ram Year:
    Engine:
    I currently have the adjustable Bilstein 5100s on my truck, running a 275/65/20 on the stock rims.
    I have a couple questions on what could be done to run 35-12.5-20 on an aftermarket rim.
    From what I have read i should set the Bilsteins up all the way. As far what rim specs I should get is where I am stuck at. Would like to know what would work...20x9, 20x10 with a -12mm or -24mm offset.
    Any input would be great. Been doing some reading on the forum and elsewhere, but can't really find anything that suggests what wheel specs to run.
  2. justin13703
    justin13703 Senior Member
    28
    978
    293
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    20x9 -12 with 35x12.5 tires works well.
  3. Snipes318
    Jan 4, 2017
    Ram Year:
    Engine:
    Any issues with rubbing?
  4. Bigdaddycodes
    Bigdaddycodes Senior Member
    21
    379
    61
    Jan 27, 2014
    Swift Current Saskatchewan
    Ram Year:
    Engine:
    20x10 -24 with a 35 and didnt rub
  5. Snipes318
    Jan 4, 2017
    Ram Year:
    Engine:
    appreciate the help
  6. justin13703
    28
    978
    293
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    Only rubs at full lock in reverse. Rubs on a tiny bit of the plastic wheel well. It's small enough I haven't even bothered with trimming it.
  7. Marciel
    Marciel Senior Member
    33
    206
    59
    Feb 4, 2017
    Ram Year:
    2006
    Engine:
    Remember that you may be in reverse wile being articulated, I'm a fan of the truck up off the tires and rubbing tires is a huge annoyance.
    Sent from my SM-N910V using Tapatalk
Share This Page
