07 front end raise
Discussion in 'Lifted' started by Tomslick, Dec 30, 2016.
  1. Tomslick
    Tomslick Junior Member
    26
    Sep 22, 2016
    Ram Year:
    Engine:
    I recently bought a 2007 Ram 1500 4x4 Quad Cab Hemi. By the way, I have always owned small Jap trucks, but, we had a baby, and I wanted something big. I am a good mechanic. Did a lot of work on this truck for 2 months to get it in shape. Lightning fast compared to my Rice Burners. Sure sucks on gas though. Ha! My struts in the front are not great. Also, I think my front end sits too low compared to the rear. I would like to replace the whole front assemblies. I read all the nightmare scenarios... If I were to install Ranchos that level it or raise it 1.5 inches, do I have to do anything else? Will this raise of 1.5 inches ruin my new tires? Will that throw the rest of the suspension off? The back shocks have been replaced and are ok. Would I need an alignment when done? Any suggestions?
  2. Jamesq87
    Jamesq87 Senior Member
    204
    87
    Aug 26, 2016
    Alabama
    Ram Year:
    2006
    Engine:
    If you lift the front, you will need an alignment. 1.5" shouldn't affect your shocks. I did 2" and am still running factory shocks for now with no issues.
  3. justin13703
    justin13703 Senior Member
    28
    1,005
    295
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    Put a set of bilstein 5100s on it and call it done. They're adjustable up to about 2 inches of lift which will level a 4wd truck. And they ride really good.
    And no it won't affect anything else. Just get an alignment after.
  4. ms8091
    ms8091 Senior Member
    118
    15
    Aug 25, 2013
    Ram Year:
    Engine:
    4.7L
    Second that. I have those on my truck and it rides nice, sits level and the truck is more stable than it was with the factory suspension.
  5. blackbeautyhemi
    blackbeautyhemi Senior Member
    28
    1,572
    532
    May 19, 2013
    Lewistown, PA
    Ram Year:
    Engine:
    Have the bilsteins on mine also and they ride better than the factory struts that were on mine.
  6. Tomslick
    26
    Sep 22, 2016
    Ram Year:
    Engine:
    Can I use Bilsteins with old springs?
    Ok I like the bilsteins but they don't have the springs around them. Can I take the old ones apart and then reuse the old springs with the Bilsteins?
  7. blackbeautyhemi
    28
    1,572
    532
    May 19, 2013
    Lewistown, PA
    Ram Year:
    Engine:
    Yupp that's exactly what ya do is reuse the spring.
  8. Tomslick
    26
    Sep 22, 2016
    Ram Year:
    Engine:
    Bilsteins
    Ok thank you! I am going to order the Bilsteins and start spraying everything down with PB blaster
  9. justin13703
    28
    1,005
    295
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    Concentrate A LOT on the lower shock mount bolt. That thing is usually an absolute bitch to get out. The nut will come off, but the bolt is usually seized in there and you have to beat the piss out of it to get it out.
    When you bolt the new bilsteins in, coat the whole bottom shock bolt in anti seize.
  10. Marciel
    Marciel Senior Member
    33
    206
    59
    Feb 4, 2017
    Ram Year:
    2006
    Engine:
    My advice is stay away from the rancho quick lift struts, had them and they are garbage. The 9000 shocks are awesome though.
    Sent from my SM-N910V using Tapatalk
Share This Page
