09+ RAM 1500 2WD/4WD FORGED ALUMINUM UCA'S
Maxtrac Suspension
Anaheim, CA
4.7L V8
Maxtrac Suspension, The leader in 2WD lift technology has delivered again with another industry first Forged Aluminum upper control arms for the 2009-18 Ram 1500 2WD & 4WD platform. These arms are made from 6082 T-6 aircraft grade forged aluminum which is substantially stronger than its billet counterpart while keeping the weight down over other steel versions. We went with factory style rubber bushings for the frame to arm which will last a lifetime and not crack or get brittle like Polyurethane and will not get loose like Heim joints.
jp_2mZg8-qPuqnyMMLZR_qATURKlt42ctCp98mggjKo
Maxtrac Suspension
Maxtrac Suspension
Anaheim, CA
4.7L V8
Note: These arms will also fit the new 2019 Ram 1500 2wd trucks. We just finished testing out the arm fitment as well as our strut spacers. Should have a final answer on the strut spacers soon but it's looking like it's going to take about 3" of lift in the front to get these '19's leveled out!
WilliamS
Tampa FL
Do the ball joints have any adjustment for camber
Maxtrac Suspension
Maxtrac Suspension
Anaheim, CA
4.7L V8
Will these fit a 2019 Ram Rebel? I've been out of look everyone telling me their spacer is not due to the rebel being pre-lifted.
No unfortunately we do not have anything for the Ram Rebel as they have the factory air suspension. sorry about that
R.L.K.
Bristol , Tn.
What's the cost & PNs for a 14 Ram 4wd ?
Maxtrac Suspension
Maxtrac Suspension
Anaheim, CA
4.7L V8
for the leveling kit? It is part# 832525 but we do not have pricing as we are the manufacturer only. Check out our dealer locator for local shops or online retailers right here http://www.maxtracsuspension.com/dealers/ let me know if you have any other questions. Thank you
alex_5_7
The rebel comes with bilstein shocks. There is an option for air ride as well but I am referring to the ones with the bilstein shocks. The set up should be exactly the same dont you think? Other than the strut being 1" longer than the oem
Maxtrac Suspension
Maxtrac Suspension
Anaheim, CA
4.7L V8
Well we have never tested these products on a Ram Rebel so I just cannot say if it will work or not. We were always told they had air ride and you cannot install spacers on them. Sorry about that I wish I had a confirmed answer
mmcquinn
