11.5 Rear Diff. Fluid Amount???
dexter
Banned
How much fluid does the 11.5 rear differential take? I put the new cover on below and was able to get in 3.5 quarts or 7 pints. The owner's manual doesn't tell you.
I do have 4.10 gears if that makes a difference.
Amsoil says 4.25 Quarts.
https://www.amsoil.com/lookup/auto-...kup/6-4l-8-cyl-engine-code-j-esa-j/us-volume/
CAPACITIES: 11.5 AA With LSD Rear 8.5 pints
PML Rear Differential Cover for American Axle 11½"
https://www.yourcovers.com/diffcover_11147.php
Volume: about 1/2 quart over stock at factory fill level
BlkZrx
northeast IN
2016 2500 SLT Std. cab
Mine took the full gallon with stock cover.
Sent from my LG-K540 using Tapatalk
D
dexter
Banned
Thanks
What size gears do you have?
What is confusing me is that I'm finding fill levels like your but with the new cover I should be able to get more in.
I am a full time RVer so I want to get it right.
BlkZrx
northeast IN
Thanks
3.73.. Fill till it won't take any more. Drive a little and check it's full and doesn't leak. Don't worry about it..
Rampant
NJ
392 Hemi
From the good book:
Fluid - Differential
Description Capacity
235AA (9.25) Front Axle 4.64 pints ( 2.2 Liters ).
235AA (9.25) Front Axle (ANTI-SPIN) 4.22 pints ( 2.0 Liters ).
292AA (11.5) Rear Axle 8.8 pints ( 4.2 Liters ).
292AA (11.5) Rear Axle (ANTI-SPIN) 8.45 pints ( 4.0 Liters ).
Caution: Nominal refill capacities are shown. A variation may be observes from vehicle to vehicle due to manufacturing tolerance and refill procedure.
D
dexter
Banned
Thanks
That's what I have.
I'll check the level again tomorrow and see if it can take any more.
I have 4.10 gears and Anti-Spin - maybe all that doesn't allow for the 8.45 pints.
