!!! $13200 to replace motor!!! HELP
Kap1
Ex Ram 1500 2013 owner
2022 Tundra
3.5 vvti
I really really hope that they'll approve you for a new motor now. You should push for it.
Tach_tech
5.7L HEMI
Sitting in traffic, shift in to park light comes on I attempt to restart and BOOOOM!!! NO MORE MOTOR!!!
What do you mean no more motor? Loud noises? Stalled and won’t start? Seized?
R
Ramguy69
HemI 5.7
The vehicle shut off, I attempted to restart and got a really bad knock. Sounded like the motor was full of gravel! To make matters worse I ordered a 2018 Ford Raptor and was going tomorrow to trade the truck and put my deposit down, but that plan is @#$^$#
Moab_Rockstar
Lake Orion, MI
5.9L
UPDATE!! I picked the truck up yesterday and spoke with the service advisor. Service advisor told me cylinders 2 & 8 had valve spring failures. Remedy, two new Pistons, lifters, valves, and a new head. All covered under warranty! Thank you everybody for all the advice I really appreciate it!!!
I don't get it. They replaced the whole head for two valve springs? The two new pistons is even more intriguing. There must have been valve to piston contact. That probably screwed up the valve guides too. That's pretty bad. I wonder if they bothered to check the balance on the rotating assembly after replacing two pistons. Ideally the replacements should have been the same weight, but I have to wonder if they at least verified or just assumed. Did they check the connecting rods were still straight?
Now that it's completely blown up, I'm betting they didn't put it back together right. Good luck man. At least this time, it shouldn't be as much of a headache since THEY are the last ones to touch the engine and it blew up after 1000 miles. :3639243774_5f528137
R
Ramguy69
HemI 5.7
Service Bill reads:
CS no start
Vehicle has low compression on cylinder number 2
R&R valve cover intake valve spring broken R&R spring
Vehicle rough idle. Remove right cylinder head number 2 and number 8 Pistons damaged period number to intake valve guide sticking, R&R two pistons and right head
Parts:
pushrod i09 4201
Spring VA 0 9 0 39015
Head engine 0 90304
Gasket kit 0 90106
Seal PVC 1 4 0 7 2 0 0 9
Piston number 0 90340 5
Gasket en 0 90104
Antifreeze 0 1 0 81004
Core return
R
Ramguy69
HemI 5.7
Second service Bill:
CS has engine tick lifters excessively noisy
R&R all lifters
Inspected camshaft shaft no dam
Tappets 09 - 85 - 01 - 10 6.4
Tappet hy 0 9041004
Tappet hy 09041004
Gasket Cy 1406 2002
Gasket Cy 1406 2002
Oil 5w 20 01081090
Oil 5w 20 01081090
Kap1
2022 Tundra
3.5 vvti
Any updates on this yet?
R
Ramguy69
HemI 5.7
No updatesome yet. I've been on the phone with FCA for the past two days trying to get this vehicle into service
huntergreen
Also wondering about a resolution.
TruckNut
Tennessee
Hard to believe that FCA would be dragging their knuckles for so long on this. Lousy customer service and enough to sour a person on the brand for life.
