Stefan N
? @16ramsportjcDo you still use the original upper controlarms with the 6112?
https://www.ebay.com/itm/47-242548-...-Kit-09-17-Ram-1500-4wd/112537040208?var=nullCan I get the 6112's complete with top mount already installed? I think I read somewhere you can but I can't find where I read that.
What I don't see there is what the height is set to.
I think I got my 6112's for under $600, I swapped over my mounts and such.
maybe the add was made 2017?Why would this fit up to 2017 but not a 2018. I have the 2018.
Likely to swap out my 5100s for 6112s myself. I added front and back Iron Bull bumpers and a Warn VR12000 winch, and my front end height took a dip (pun intended) and I definitely need stronger front end. My plan is also to go from the Zone 4" to the 6" lift (by adding just the 2" strut spacer from Zone), set the 6112s to 2.6 and add a 1" spacer in the back. That should have me good to go.Thanks, JB1! Lots of good experience and info there.
Probably will go this route...although the Icon and Falcon kits have me salivating. Want vs need I suppose. The 5100s are just not quite up for my intended use and I think I need a step or two up from that...at least in the front.
Any 6112 owners have issue with the shocks settling/sagging after a bit? How accurate are the measurements vs the lift you actually get?
Another thing to consider is I intend to add an aftermarket bumper to the front...which will weigh about 190-200#...
Thanks
Thanks
Im in bad street california (palmdale)
Falcon kit?
Well maybe for what your gonna be doing those may be a better choice. Most guys here don’t do any hardcore or daily off-roading like you plan on doing so the Bilsteins work just fineSorry, I misspoke. Icon kits and Falcon shocks.
