1985 Dodge Power Ram W150 steering
Discussion in 'Tech Info' started by Brucecmc, Nov 25, 2016.
  1. Brucecmc
    Brucecmc Senior Member
    123
    Nov 21, 2016
    At the parts store
    Ram Year:
    1985 Power Ram W-150
    Engine:
    318 V8 5.2L
    Not following that Wolfie. Just pound the pin and the plastic piece at same time ? I think it's moot. I'm already pressing forward with mashing down those flanges and devising a way to shore that up some. When I figure something out I'll post it.
  2. crazzywolfie
    crazzywolfie Senior Member
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    do you got a proper roll pin punch? usually it should just push it right out with a roll pin punch. i did about 2 or 3 a couple months again and all came apart pretty easy but none of my steering boxes were on a vehicle.
  3. Brucecmc
    123
    Nov 21, 2016
    At the parts store
    Ram Year:
    Engine:
    318 V8 5.2L
    I have several sizes of punches. Dunno if they're "proper" or not. But, I think I'll save this for a future effort. Like when I decide this crappy set up needs to be replaced with the borgeson heavy duty telescopic steering shaft #000940 (which I probably should have done instead of this). Guess I was more curious than anything on this effort.
  4. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    ya normal flat tip punchs are definitely not the same as a rollpin punch. a roll pin punch has a little bump on the tip the keep the roll pin from bending in when you hammer on it. sometimes having the proper tools makes things so much easier but then again you live and learn. a borgeson steering shaft is the best route to go especially if you plan on keeping the truck.
  5. Sniper X
    Sniper X Senior Member
    49
    113
    10
    Dec 7, 2016
    Ram Year:
    1991
    Engine:
    318
    I did the Borgesson shaft on my 1977 Ramcharger and it rocked. The stock one was sloppy and dangerous.
  6. ajs196
    ajs196 Junior Member
    21
    Nov 26, 2016
    Ram Year:
    1980
    Engine:
    360 5.9L
  7. Bill1982
    Bill1982 Junior Member
    11
    Oct 10, 2017
    Ram Year:
    1982
    Engine:
    360
    I did mine the cheap way picked up a lower steering shaft with a ujont in it from a late 90s Tahoe shorten my stock shaft carefully ground flats on each side to slide it together and clamped the u joint to the steering box input shaft cost a whole 12$ for the lower shaft off the Tahoe when I did a 3"body lift later the shaft wasn't an issue it's still on and no issues
    Sent from my Z832 using Tapatalk
Share This Page
