1987 Dodge Ram
Discussion in 'General Discussions' started by saxman2584, Nov 27, 2016.
  1. saxman2584
    saxman2584 Junior Member
    Nov 27, 2016
    Ram Year:
    1987
    Engine:
    So I am about to get a 1987 Dodge Ram from my grandfather that has been sitting for about 8 years. The truck was in excellent condition before my grandfather's health declined. He always took very good care of his vehicles. What is the first steps, I figure of many, to get it up and running. Have a new battery already.
    Sent from my SM-G935V using Tapatalk
  2. d250
    d250 Member
    18
    99
    Feb 18, 2016
    Ram Year:
    1991
    Engine:
    5.2 318 v8
    Drain the gas tank and put fresh gas in and put the new battery in and it should run.
  3. saxman2584
    Nov 27, 2016
    Ram Year:
    1987
    Engine:
    What is the best way to drain the gas?
  4. MADDOG
    MADDOG Super Moderator Staff Member
    7,138
    1,881
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    I'd drain any fuel in the truck and try some carb cleaner down the throat of the carb. Check the carb butterflies for proper operation. Give the throttle linkage a good spray down with WD40 or PB Blaster to free it up if it is froze in place.
    Drain the engine oil, service the differential(s). New lube and filters. Check the transmission fluid and PS fluid and brake fluid levels. Eventually you'll want to flush and refill all those systems.
    Pull the plugs and inspect them. I would expect you'll need a fresh set along with some new plug wires as well.
    Check the coil connections. Check the connection at the starter and the main ground for corrosion.
    Starter fluid is your friend for priming the carb when you are ready to start it up.
    Lastly, have fun!!!
    reek and saxman2584 like this.
  5. MADDOG
    7,138
    1,881
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Dropping the tank is the best way. While you are at it you can add a fuel system/tank cleaner and remove all the old varnish and crap inside the tank.
    Also, check the fuel line connections at the tank. That old hose is probably dried out and cracked. If so, it indicates any rubber fuel lines will need replaced.
  6. crazzywolfie
    crazzywolfie Senior Member
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i wouldn't worry about draining the tank or anything like that yet. check fluid/oil levers and then try starting it with some brake cleaner or any flammable oils in spray cans. the truck may start and possibly run on the gas that is still in it. once you get it running then go from there. check the brakes and brake lines for rust since the brakes are important. the rest is not too important. you can inspect and replace other stuff as you go.
    RonJon '06 likes this.
  7. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i am kind of surprised John did give us some of his wisdom. he has lots of experience firing up older vehicles that not run in a while. here is his trucks thread that he started. hopefully even just the first post will give you some hope that things are really not as bad as people make things seem.
    http://www.ramforum.com/f135/my_power_ram_350_a-51177/
  8. RonJon '06
    RonJon '06 Senior Member
    3,290
    1,041
    Jan 2, 2014
    Southern Minnesota
    Ram Year:
    2006, 1985
    Engine:
    5.7, 360
    That's because I thought you guys covered it pretty well lol.
    My '85 started right up and ran fine with the 20 year old gas that was in the tank. The only thing I'd add is change the fuel filter after a day or two then again after you put some miles on it. It seems to me that the brakes suffer the most from sitting idle.
    saxman2584 likes this.
  9. saxman2584
    Nov 27, 2016
    Ram Year:
    1987
    Engine:
    Cool thanks for the tips... headed back home to work on it in 2 weeks. Will keep y'all updated!
  10. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    good luck and if you have any question just ask. someone is bound to know
    haha ya. we did cover quite a bit but i figure there might have been something missed. i know you didn't fire up every vehicle from your dads place but i know you did a few and almost all the ones you tried fired up. they definitely don't make gas the same as they use to lol
Share This Page
