1989 W100 Fuel Delivery Issue
Discussion in 'General Discussions' started by rustyram89, Dec 22, 2016.
  1. rustyram89
    rustyram89 Junior Member
    Nov 30, 2016
    Ram Year:
    1989
    Engine:
    318
    Hey everyone, I have an '89 Ram W100 with the 318, TBI. It starts up fine, runs for about 10 seconds smoothly, then sputters out. It doesn't seem to only happen when the idle drops too low, you can give it a little gas and keep the idle up, and it still dies. It will do this over and over as well, so I feel like it's getting a little bit of gas?
    You can hear the fuel pump in back in the gas tank kick on for a couple seconds when you turn the key, and i don't think it has anything to do with the distributor since it doesn't misfire and runs smoothly--for a few seconds then dies.
    I don't have a ton of experience with fuel delivery systems, so any advice to point me in the right direction is much appreciated!
    Thanks!
  2. Sniper X
    Sniper X Senior Member
    50
    113
    10
    Dec 7, 2016
    Ram Year:
    1991
    Engine:
    318
    Does that year have the electronic hall effects sensor in the dizzy like my 1991? If so that might be it. Mine did the same thing and some other stalling no start problems right before it quit. I replaced it and haven't had a problem since.
Share This Page
