1992 B350 Van Need Help hooking up Trailer wires
matvous
Murphytown, WV
I have all working with exception of Brake light wire . can anyone tell me where to steal brake light power and what color. Thank you
crazzywolfie
under the truck
what do you need brake light wire for? if you are needing it for a brake controller you got to get it off the brake switch. if you are just wiring a standard 4 pin connector the left and right brake light/turn signal should be where you get power from for the connector.
