tulum69
- Aug 19, 2012
- 3
- 0
- 1994
- Magnum 5.2
Hello
I recently purchasd this Ram, replaced the ignition and battery and got it running, runs and starts great, only issue for now is a metallic rubbing sound while it is in gear, has a manual transmission and I beleive it may be the clutch, just wish to verify as the scrapping sound has resonance and sounds like it is coming from between the cab and bed underneath, when I am in netrual there is no sound, when I shift through the gears the scraping sounds through all the gears but goes away when I place it in netrual, clutch pedal it self is stout like it should be and there is no sound when I press the clutch in netrual.
The sound also wavers with the engine speed as it revs up and down while in gear.
Any info will be helpful.
