Replaced the plenum, now truck will start and die. checked everthing twice, swapped IAC, map, and tps from running truck to this one, still same issue. restarted truck, everthing worked great. then we realized we had left the vacuum line off the brake booster, plugged it up, truck immediatly died. pulled line back off, restarted truck, it started and ran. plugged the vacuum line to the booster, immediatly died...... never seen an engine run better with a vacuum leak, than without one. Any suggestions?
