2) 10's or 1) 12
Discussion in 'Audio & Electronics' started by shawn1112, Dec 31, 2016.
  1. tcazes
    tcazes Senior Member
    194
    47
    Dec 7, 2016
    Ram Year:
    Engine:
    5.7L
    Lol glad I could help!
  2. Etroze86
    Etroze86 Senior Member
    4,807
    834
    Nov 4, 2012
    Grand Forks ND
    Ram Year:
    Engine:
    Negative, it all depends on sub woofer and enclosure. I have an 18 that will play cleaner and lower than most 10s in its price point.
    adrianp89 likes this.
  3. Ferro
    Ferro Senior Member
    435
    191
    Sep 17, 2016
    Ram Year:
    Engine:
    Isn't that what I just said. Lol. It's all about how much air you can move.
  4. hemi1282
    hemi1282 Senior Member
    35
    697
    134
    Jul 3, 2012
    Arkansas
    Ram Year:
    2016 Ram Tradesman Crewcab
    Engine:
    Where are u getting your fox box at? I've been tryna get a box from foxacoustic.com for the past three weeks dunno what's going on over there guess they gone for the holidays, is there other places to get one at?
  5. adrianp89
    adrianp89 Senior Member
    28
    1,940
    623
    Sep 3, 2015
    Tampa Bay, FL
    Ram Year:
    Engine:
    This is 100% wrong. It is completely dependent of the subwoofer and the enclosure.
    Either way I still would say 2 10s based on displacement.
    Etroze86 and djarrett like this.
  6. tcazes
    194
    47
    Dec 7, 2016
    Ram Year:
    Engine:
    5.7L
    You find me a 12 that will cycle faster than a 10 and I'll believe you. It's a bigger coil. Bigger magnet and bigger surface area. There is no way you will ever make a 12 cycle as fast or as crisp as a 10
  7. adrianp89
    28
    1,940
    623
    Sep 3, 2015
    Tampa Bay, FL
    Ram Year:
    Engine:
    I can easily find you 12" woofers with smaller coils and motors than 10s. Other things to take into consideration are also the strength of the spider, cone material (lighter cones vs heavier cones), as well as T/S parameters. This isn't even an argument, it is speaker basics 101. This argument is something I would hear from the 16 year old whose system hits 212dBs.
    Extreme example:
    Your 10" SPL sub:
    NSV3 SERIES
    Your 12" entry sub (smaller coil and motor):
    http://www.sonicelectronix.com/item_98697_JBL-S2-1224-Toggle-between-2-Ohm-4-Ohm-Impedance.html
    Just for shits and giggles here is a 18" speaker that can play higher than most subwoofers. Playing higher means it can "cycle faster" because of the higher frequencies. (1200hz is 1200 times a second, 40 hz is 40 times a second).
    http://www.parts-express.com/eminence-sigma-pro-18a-2-18-cast-frame-driver--290-427
    Etroze86 likes this.
  8. tcazes
    194
    47
    Dec 7, 2016
    Ram Year:
    Engine:
    5.7L
    There's so.e definitive proof. Thank you sir.
  9. THETANK
    THETANK Senior Member
    53
    2,197
    641
    Jul 24, 2014
    up jor azz mang
    Ram Year:
    2015 R/T
    Engine:
    eh just hook up an old ghetto blaster circa 1980's and bam you are done. Rock on!
  10. 57buick
    57buick Senior Member
    171
    63
    May 2, 2015
    Salem, OR
    Ram Year:
    Engine:
    6.7L diesel
    the JL Audio 13" shallow mount will blow 2 10's away. Seriously and it only requires one cubit foot of space. This is what Im putting in my truck after hearing it in a couple other trucks with 500w on it. It comes in 2 ohm or 4 ohm I think depending on your wiring configuration
    13TW5-3 - Car Audio - Subwoofer Drivers - TW5 - JL Audio
    13TW5
Share This Page
