Craigart14
- Oct 25, 2017
- 9
- 0
- 2000
- 5.9
2000 Dodge RAM 3500. On startup, stalls but will not idle. With a little gas, it runs fine, but I have to brake with the left foot because it stalls if I take my right foot off the gas.
Oil gauge and fuel gauge max out, but charge gauge drops to zero. After driving a while, for some unknown reason, gauges return to normal, showing good oil pressure, 14-16 volts charge, and correct fuel amount.
Then it quit on the highway after 1000 miles. Battery ($180 Interstate only three months old) was dead, so dead the local Walmart said it couldn't be charged. So new battery. Nearby AAA rated shop replaced the coil, telling me that the "old" coil actually looked pretty new, but was cracked and arcing.
Ran OK for a couple of hundred miles, though still with gauge fluctuations.
Then quit. I put in a new crank sensor. Another shop replaced the coil again and put in new distributor cap and rotor. Seemed to run fine, but a few days later the battery was dead again. Following online advice, I installed an external voltage regulator, jump started the engine, and all seemed well: smooth running, no stalling, normal gauge readings. Unplugged the regulator to keep if from draining the battery, then plugged it in and the gauges went haywire again. Battery is dead again despite 24 hours on a Battery Tender.
I would connect the regulator to the fuse box so turning off the ignition would break the circuit, but I can't figure out how to do that with square fuses. No add a fuse for that. So I think I will wire a switch to the dash so I can shut off the regulator manually.
Any ideas why it stalls? Or why batteries keep going dead?
All suggestions appreciated.
