Craigart14
- Oct 25, 2017
- 9
- 0
- 2000
- 5.9
Van quit while driving and would not restart. Mechanic installed new coil, problem seemed to be solved. A few hundred miles later, van quit while idling. Starter cranks, but engine doesn't fire. Replaced crankshaft sensor, which didn't help. I couldn't hear the fuel pump, so I sprayed starter fluid into the air intake while cranking, but engine didn't fire. Mechanics yesterday tested fuel pressure, which was good, but then tested spark and found none. Good spark from coil to distributor, but no spark from distributor to plug wires. Replaced cap and rotor, but still had spark to distributor but not from distributor to wires. Mechanics at this AAA approved shop are stumped.
Any ideas? I have also tried the key dance, but it showed no codes, and I disconnected negative battery cable for 30 seconds, but it didn't help. Still stumped.
Craig
Craig
