2000 leveling kit
Discussion in 'Lifted' started by Cled48, Dec 17, 2016.
  1. Cled48
    Cled48 Junior Member
    Dec 11, 2016
    Ram Year:
    2000
    Engine:
    5.9L
    I plan on buying a 2.5" leveling kit for my 2000 1500 4x4 tonight from hell bent steel. Anything I should beware of? Such as one tire sticking out for some odd reason ?
  2. 05ram4x4
    05ram4x4 Senior Member
    596
    29
    Aug 28, 2012
    Ram Year:
    2002 Ram 2500 4x4 Quad cab
    Engine:
    5.9 Magnum
    One tire will stick out a little more as the axle shifts over as the front end goes up. Therefore, the opposite tire will set in the fender more.
    The wheels will also sit further back in the truck, as the axle comes back as the front end goes up.
  3. Jrock2394
    Jrock2394 Senior Member
    168
    56
    Feb 8, 2014
    Ram Year:
    1996
    Engine:
    5.2 V8
    Replace your shocks with extended ones while you're in there. I would stay away from Rancho, I had to install washers on the bottom mount because the bracket on the rancho was way to narrow and caused a popping feel over bumps.
Share This Page
