Jpryor426
I’ve been having an overheating issue for the past couple weeks on my 03 Ram with the 5.7. To begin, for the last 6 months it has been running too cool. I attributed that to being the thermostat stuck open. A couple of weeks ago I finally replaced the t-stat and it started to overheat with the heater blowing cold. And there was not leaks and the coolant level remained the same. I figured there was air or a clog in the system somewhere, so I flushed the system and filled it with an Airlift vacuum tool. Still overheating and still no heater. I then flushed only the heater core and filled it with the vacuum tool. So heater started blowing hot but the truck still got hot. I then got a water pump, the old one seemed fine but the bearings were clicking so I replaced it anyway. There was no change after replacing. I still have heat now but the truck gets hot.
Is there any tricks to get the air out of the system on the 03 hemis? It’s the one that has the sealed radiator with the cap on the external expansion tank.
