2005 dodge ram 1500 5.7 hemi
Paula Brown
Turns off while driving,radio is gone now it will crank back up after a few tries but gives no signs it's going to cut off any ideas on what it could be
SYKRAMMAN
Banned
Jersey shore
06 Mega
It could be a multitude of things like cam sensor or crank sensor or asd relay, tipm, etc, etc. the best thing to do before you start just throwing parts at it is to have it put on a live data scanner, at least you’ll be able to tell what it is or get close to what it is. Or you can test each individual sensor to narrow it down.
14RAM1500BG
maryland
I had to replace my crank sensor a while back but as stated above it could a lot of things causing that to happen.
CaptainEd
South Florida
Mine was randomly stalling and throwing crank sensor codes. I had a mechanic replace both and the problem went away for a couple of weeks then returned. As it turns out, the mechanic didn't put OEM sensors in as I asked. Replaced them with new OEM and the problems was gone.
am3334
