rsnider2
Hello I need some help, I can not get my working fob to go into program mode to program another fob.
The remote works fine unlock, lock and panic but after step 3 it does nothing. I have tried waiting longer and waiting less but still no tone or anything after panic.
It is for a 05 Ram 1500 Daytona any help would be great.
1. Put key in ignition and turn ignition switch to ON position (last stop before cranking the engine).
2. Press and hold UNLOCK on a currently functioning remote for 4 to 10 seconds.
3. While holding the UNLOCK button during the 4 to 10 second period, press the panic button for one second and release both buttons at the same time. A
chime should sound within three seconds to indicate the vehicle has entered programming mode.
4. Press the Unlock button on the remote used in step 3. You should hear an audible tone indicating that remote has been re-programmed. This step must be done within 30 seconds of hearing first chime in step 3.
5. Within 30 seconds – Press the Unlock button on the next remote.
-Repeat step 5. for all additional remotes including working remotes
6. Programming is now complete. Turn ignition off and test remotes to ensure proper programming.
