2010-2012 6.7L Service Data & Part #s
Discussion in '6.7 Common Rail' started by Trupiano, Jul 13, 2013.
  1. Trupiano
    Trupiano Registered User
    33
    10,982
    667
    Jun 27, 2010
    Hometown : Puyallup,WA Stationed : Little Rock,
    Ram Year:
    2010 Ram 2500 6.7L CTD Crew Cab
    Engine:
    6.7L CTD
    2010-2012 6.7L Turbo Diesel Engine Service Info:
    Engine Oil Filters: MOPAR# 05083285AA or MO-285 | CUMMINS# 3949561 | FLEETGUARD# LF3972 (standard 30 microns at 95%) or FLEETGUARD# LF16035 (upgraded/fluted stratapore version 30 microns at 100% / 10 microns at 60%) | AMSOIL# EA080 (15 micron at 98.7%) $18.85 each wholesale or $24.80 retail | ROYAL PURPLE# 40-780 (99% filtration at 25 microns) | DONALDSON# ELF7349 | WIX# 57620 (standard/20 micron) or 57620XE (high efficiency/14 micron) | NAPA GOLD# 7620XE (14 micron) | FRAM# PH3976A (standard) or HPH3976A (extended life) | BALDWIN# BT7349
    Fuel Filters:
    MOPAR 68157291 NANONET two stage fuel Filter (5 micron outer/3 micron inner) | MOPAR# 68065608AA (5 microns at 98.7%) | FLEETGUARD# FS43255 (5 microns at 98.7%) | CUMMINS# 4947561 (5 microns at 98.7%) | WIX# 33255 (12 micron at 100% / 5 micron at 98.7%) | NAPA# 3255 (12 micron at 100%) | Baldwin#
    Air Filter: MOPAR# 53034051AB | FLEETGUARD# AF27684 | WIX# 46930 | NAPA# 6930 | FRAM# CA10261 | PUROLATOR# A56314 | DONALDSON# P616743 | BALDWIN# PA4318
    68RFE Transmission (4x4 only): MOPAR Sump Filter# 5013470 | MOPAR Screw On# 5179267
    68RFE Transmission (4x2 only): MOPAR Sump Filter# 5013470A | MOPAR Screw On# MOP-5179267
    AISIN Transmission (4x2 & 4x4): MOPAR Sump Filter# 68019688 | MOPAR Pan Gasket# 68020049
    Crankcase Vent Filter (CCV): CUMMINS# CV520010
    Engine Oil Viscosity: In ambient temperatures below 0°F (-18°C) 5W-40 synthetic engine oil that meets Chrysler Materials Standard MS-10902 and the API CJ-4 engine oil category is required. In ambient temperatures above 0°F (-18°C) 15W-40 engine oil that meets Chrysler Materials Standard MS-10902 and the API CJ-4 engine oil category is required. *Change engine oil when prompted by the Engine Oil Indicator System or every 7,500 miles/12,000km or 6 months. Uses 12.1 Quarts/11.4 Liters/3 gallons. *Can use MOPAR DIESEL FRESH Oil Additive PN: 05139947AA to neutralize the smell during oil changes if preferred. The four-ounce Diesel Fresh bottle treats up to 12 quarts of diesel engine oil. For easy removal use this End Cap Filter Wrench: LISLE 54780 END CAP FILTER WRENCH-Dodge Cummins Diesel Truck Accessories – Geno’s Garage **Your vehicle is equipped with an engine oil change indicator system. This system will alert you when it is time to change your engine oil by displaying the words “Oil Change Due” on your Electronic Vehicle Information Center (EVIC). The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate depending on your per- sonal driving style. Driving styles such as frequent stop and go type driving or extended idle time can increase the frequency of the engine oil change. Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Trip Odometer button on the instrument cluster. To reset the oil change indicator system: (after performing the scheduled maintenance) 1. Turn the ignition switch to the ON/RUN position (do not start the engine). 2. Fully depress the accelerator pedal slowly three times within 10 seconds. 3. Turn the ignition switch to the OFF/LOCK position. NOTE: If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary, repeat this procedure.
    Transmission Service: Automatic Transmission (68RFE): MOPAR ATF+4 Automatic Transmission Fluid or equivalent. *Change automatic transmission fluid and filter(s) every 60,000 miles.
    Automatic Transmission Chassis Cab (AS68RC): MOPAR AS68RC Automatic Transmission Fluid or equivalent. *Change every 30,000 miles (48,000 km) or 24 Months
    Manual Transmission (G-56): MOPAR ATF+4 Automatic Transmission Fluid or equivalent. *Change the manual transmission fluid at 120,000 Miles (192,000 km) or 96 Months.
    Fuel Filter Service: Replace fuel filter every 15,000 miles or 12 months using MOPAR Fuel Filter or equivalent. *Must meet 5 micron rating. Using a fuel filter that does not meet the manufacturers filtration and water separating requirements can severely impact fuel system life and reliability. For easy filter removal use this $6.95 Cummins Fuel Filter Removal Tool: LISLE 14600 CUMMINS FUEL FILTER REMOVAL TOOL-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
    Fuel Tank Capacity: 34 Gallons / 29 Liters (short bed) or 35 Gallons / 132 Liters (long bed). *Commercially available fuel additives are not necessary for the proper operation of your Cummins diesel engine. Use MOPAR Premium Diesel Fuel Treatment # 5191800 or equivalent as needed. Use Valvoline Synpower Diesel Injector Cleaner or equivalent as needed to clean and lubricate injectors and pump.
    Radiator Service: Use MOPAR Antifreeze/Coolant 5 Year/100,000 mile formula or equivalent. *Flush and replace engine coolant every 60 months or replaced at 97,500 miles (157 000 km). Uses 5.7 Gallons or 21.4 Liters of coolant
    Transfer Case Service: Change the transfer case fluid (4x4) every 60,000 miles (96,000 km) or every 48 months. Use MOPAR ATF+4 Automatic Transmission Fluid or equivalent. Fluid level can be checked by removing the filler plug and inserting a finger. The level of the lubricant should not be more than 1/2 in (12 mm) below the bottom of the filler hole while the vehicle is on level ground.
    Power Steering Service: (3500) Flush and replace power steering fluid at 97,500 Miles (157,000 km) or 78 Months. (2500) Flush and replace power steering fluid at 105,000 Miles (168,000 km) or 84 Months. Use MOPAR ATF+4 Automatic Transmission Fluid or equivalent.
    Front/Rear Axle Service: Inspect the front (4x4) and rear axle (2x4 & 4x4) fluid and change if using your vehicle for police, taxi, fleet, off-road or frequent towing every 15,000 miles (24,000 km) or 12 Months. Rear Differential: (8.5 pints or 4.2 quarts (LSD) / 8.9 pints or 4.5 quarts (Open) Front Differential: (4.7 pints or 2.4 quarts)
    Front Drive Shaft: Grease Front Driveshaft Fitting at each oil change interval, every 7,500 miles or 6 months. Use MS-6560 Lithium Base Grease #05083150AA or equivalent. (must use grease gun needle adaptor) Buy Performance Tools 4" Grease Gun Needle Nose Adapter W54216 at Advance Auto Parts Here is a picture of where the fitting is on the driveshaft:
    Clutch Linkage: Lubricate using MOPAR® Multi-Purpose Grease, NLGI Grade 2 E.P. or equivalent.
    Crankcase Ventilation Filter (CCV): Replace Crankcase Ventilation Filter every 67,500 miles (108,000 km) or every 54 Months. Use MOPAR CCV Filter or equivalent.
    Diesel Particulate Filter (DPF): Clean every 200,000 miles, 6500 hours (anually if used vocationally) or if notified by by on-board computer.
    Overhead Adjustment: Adjust every 150,000 miles, 5,000 hours or 4 years. (any excessive lash or need of constant adjustment may indicate tube, rocker, and or camshaft are damaged)
    Cabin Air Filter: Add this mod to ensure proper HVAC air flow inside the cab and replace as flow decreases or filter gets dirty. DODGE RAM CABIN AIR FILTER KIT ('10-'12)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
    EGR Cleaning Kit: 6.7L EGR CLEANING KIT W/O FILTER ('07.5-'12)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
    Turbo Drain Tube: The stock drain tube is only about 9-1/2" long and too short for aftermaket turbos unless you get lucky(extremely unlikely). The 3rd gen turbo drain tube is 11" long and fits way better. Cummins PN# 3970875 or get it here: Cummins Stock Length Flexible Turbo Drain Tube 5.9L 3970875 don't forget to get a new turbo drain gasket PN# 5264568
    * Any brand product that meets or exceeds the factory OEM products “should” be ok to run however I would like to point out that Cummins developed Cummins Filtration in 1958 to meet the high performance requirements of Cummins diesel engines and manufactures Fleetguard filters. Cummins also endorses and recommends Valvoline Oil. This by no means discounts other brand products or quality but many will argue these Cummins endorsed/manufactured products are the best for a Cummins engine.
    With that being said here are some products/feedback/prices and places to buy them from. Feel free to post your favorites or comments on products for the 6.7L
    swp1983 likes this.
  2. Trupiano
    33
    10,982
    667
    Jun 27, 2010
    Ram Year:
    Engine:
    6.7L CTD
    Engine Oil:
    Valvoline Premium Blue 15W40 Diesel Engine Oil $14-16 per gallon (great all around oil, Cummins endorsed) (Valvoline)
    Valvoline Premium Blue Extreme 5W40 Diesel Engine Oil $20-35 per gallon (great for the winter or extreme cold temps, Cummins endorsed) (Valvoline)
    AMSOIL Synthetic 15W-40 Diesel Oil (DME1G) $29.80 per gallon wholesale / $38.70 retail or $113.40 per 4 gallons wholesale / $153.10 retail
    AMSOIL Synthetic 5W-40 Premium Diesel Oil (DEO1G) $30.40 per gallon wholesale / 39.50 retail or $115.80 per 4 gallons / $156.35 retail
    Royal Purple 15W40 Diesel Engine Oil #RP-1154 $8-9 per quart
    Rotella T Triple Protection 15W40 Diesel Engine Oil $13-14 per gallon or $3-4 per quart (Shell)
    Rotella T6 Synthetic Extreme Temperature 5W40 Diesel Engine Oil $21-22 per gallon (Shell)
    Mobil One 5W40 Synthetic Diesel Engine Oil $25 per gallon (Mobil)
    Mobil Delvac 1300 Super 15W40 Diesel Engine Oil $13-14 per gallon (Mobil)
    Delo 400LE Heavy Duty Motor Oil 15W40 $12-13 per gallon or $3-4 per quart (Chevron)
    Auto Transmission Oil / Transfer / Power Steering:
    AMSOIL Synthetic Multi-Vehicle Automatic Transmission Fluid (ATF1G) $34.85 per gallon wholesale / $45.20 retail or per 4 gallons $132.60 wholesale or $179.05 retail
    AMSOIL Synthetic Multi-Vehicle Automatic Transmission Fluid (ATFQT) $8.90 per quart wholesale / $11.50 retail
    Royal Purple Max ATF Synthetic Transmission Fluid (RP-1320 $12 for 1 quart) (RP-12320 for 12 quarts) or (RP-5320 for a 5-gallon pail)
    Front Differential / Rear Differential:
    AMSOIL SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) $11.55 per quart wholesale / $14.90 retail
    AMSOIL 75W-90 Synthetic Long Life Gear Lube (FGRQT) $9.50 per quart wholesale / $12.35 retail (FGR1G) $37.45 per gallon wholesale / $48.55 retail
    Royal Purple Max-Gear 75W-90 (RP-1300 for 1-quart bottle) (RP-12300 for 12 1-quart bottles) (RP-5300 for a 5-gallon pail)
    Brake Fluid:
    AMSOIL Brake Fluid DOT-3 (BF3SN) $5.50 per 12oz wholesale / $7.20 retail
    Grease:
    AMSOIL Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR) $9.14 per 14oz cartridge wholesale / $12.75 retail
    AMSOIL Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCCR) $5.41 per 14 oz cartridge wholesale / $7.55 retail
    AMSOIL Synthetic Water Resistant Lithium Complex Grease; NLGI #2 GC/LB (GWRCR) $5.82 per 14oz cartridge wholesale / $8.10 retail
    Royal Purple Ultra-Performance Grease (UPG) (RP-1312 for 14½-Ounce Tube) (RP-30312 for 10 14½-Ounce Tubes)
    Additives:
    Valvoline Synpower Diesel Injector Cleaner $16-17 for 32oz
    Mopar Diesel Fresh $9-10 for 4oz
    Mopar Premium Disel Fuel treatment $7-8 for 11oz
    Fleetguard Fleet-Tech CC2588 Turbo Diesel Fuel Additive $8-9 for 16oz
    Fleetguard Fleet-Tech CC2592 Winter Conditioner $7-8 per quart
    Fleetguard CC2597 Asphaltene Conditioner $9-10 per quart
    Assembly Lube:
    Royal Purple Max-Tuff Assembly Lube (RP-10553 for 2-ounce bottle) (RP-1335 for 8-ounce bottle) (RP-12335 for Case of 12 8-Ounce Bottles)
    Torques:
    Oil Drain Plug.....37 ft/lbs
    Manual Transmission G56 Fill Plug 42 ft/lbs and Drain Plug 42 ft/lbs
    Transfer Case NV271 Fill Plug 15-25 ft/lbs and Drain Plug 15-25 ft/lbs
    Transfer Case NV273 Fill Plug 15-25 ft/lbs and Drain Plug 15-25 ft/lbs
  3. txeagle
    txeagle Junior Member
    Sep 23, 2013
    Ram Year:
    Engine:
    6.7
    Great Post! Do you have the specs for the 2013 + model years?
  4. sam1286
    sam1286 Junior Member
    49
    Oct 4, 2013
    Ohio
    Ram Year:
    Engine:
    Cummins
    X2 on the 2013 info
    Thanks
  5. Roon Dog
    Roon Dog Junior Member
    Aug 31, 2017
    Ram Year:
    Engine:
    Cummins I6 6.7L
    Wow!
    I know this is an old post, but I've never before seen such a comprehensive collection of maintenance data all in one place! Thank you for posting. Trying to find this information in all the different locations is akin to pulling (my own) teeth.
    That being said, as another poster requested, it sure would be good to see the same info for my 2013 3500.
  6. Tim Bingley
    Tim Bingley Junior Member
    43
    Jan 1, 2018
    Lac La Biche, AB
    Ram Year:
    Engine:
    I’ve been using fleetguard fuel filter FS53000. What is the info on that one ?
Share This Page
