2011 ram 1500 4.7 4x4 please chime in
808ram1500
Big Island, Hawaii
4.7L
I need to k ow what color the stock OEM plug on the kickdown solenoid is. Located on the top of the tranny, middle, drivers side. The actual plug and not the connector that goes over it. Need to know the color cause the REMAN part didn't fix the problem and I need to order a factory part. Thanks.
Ram13BH
Orlando, FL
6.7L CUMMINS
It's going to be either white or gray. Sometimes the VIN will tell the appropriate one for your truck, so if you want to post the last 8 digits of your VIN or send it to me in a PM, I will be happy to see if I can tell you. The design change affecting your truck actually occurred in 2011, so you could have had either one. In may cases, the white will still work in place of the gray, but not the other way around.
1Popeye
