2013 2500 35" w/ 2" level
SalmonKiller
washington
I have a 2013 6.7 2500.
2" level kit.
XD addict wheel 20x9 w/ +18 offset.
I was wondering if i will have rubbing issues if i get some 35 12.5 20 NItto ridge graplers?
UpInSm0kE
2019 Ram 2500 Tradesman
You should be fine, typically you would only rub if you were using the Stock OEM Rims with a +54 offset. I ran 295/70r18 on +18 and 285/75r18 (35x11.50) with a 2" level and never got close to rubbing. I am running 18" XD Monster Rims with a +18 offset as well.
Saugie53
North Kingstown, Rhode Island
Just putting my 2 cents in...you might wanna try and do a little more research...i did the same thing on my 2013 2500 everyone was saying 35's fit fine with no rubbing...I bought the oem black 20" wheels and went with 285/65/r20 goodyear wrangler duratrac tires just to be safe and sure enough i have a little bit of rubbing...its only on full lock each way the insides of the tires rub against the radius arms...apparently in 2013 ram changed the suspension but only on the 3500's they didnt change the suspension on the 2500's until 2014 so people saying they fit on their 2014 and newer 2500's will be different then yours...its not bad rubbing and i can deal with it...i have actually learned to stop right before i get to full lock so it doesnt bother me that much and usually if they do rub i am driving very slowly so nothing happens...just didnt want you to go with a set of tires based off what other people with newer trucks were saying fit theirs like i did...i mean with a 2" level and the fact that you arent going with the stock wheels which have a horrible offset might be enough to make a difference
UpInSm0kE
He stated that he is using aftermarket +18 offset not the OEM Wheels. The OEM 20" are offset +54 which will rub if you go to wide but with +18 offset aftermarket he should have no issues.
I'm surprised you rub with a 285 on stock rims. I had stock rims with a 285 before my Monster's and I never rubbed at full lock. Mine measured (34.8x11.2)......
MADDOG
Out Exploring Arizona
You should be fine. I did XD Addict +18mm offset wheels with 35's & a 2" level on my 2014, Walker Evans 504 Legacy +12mm offset wheels with 35's & a 2.5" level on my 2017. No rubs ever.
