2013 2500 35" w/ 2" level
SalmonKiller
washington
I have a 2013 6.7 2500.
2" level kit.
XD addict wheel 20x9 w/ +18 offset.
I was wondering if i will have rubbing issues if i get some 35 12.5 20 NItto ridge graplers?
zeddy
Burbank, Ca
Will fit. Might rub a little if you have wheels locked going up and incline (driveway). I have a 2inch with 0 offset. Mine rubs. Keep in mind, mines a gasser . If you get a 2inch spring make sure they're for a diesel. Springs for the gasses are a little softer. If it's spacer, you should be good to go.
Samario1984
I have a 2011 with stock wheels and 35 12.50s and the only rubbing is on my control arms. My truck is also leveled. With an offset it may rub elsewhere.
FiStER
Fort Drum
6.4L Hemi
2500 w leveling kit running 35x12.5 on 20s...minimal rubbing think its just the treads on newish trail grapplers...nothing serious and only at full swing...like zeddy said on incline it'll rub...level ground should be fine
