Hey guys, working on a 2013 Ram 3500 and we are removing the factory projector/led light to install a set of black Recon headlights. We have everything working fine except it keeps showing a turn signal light out code once we start the truck. We have even installed a halogen turn/DRL bulb and installed a 6ohm 50 watt resistor in the turn wire (other side to ground) and also on the DRL wire and it still trips the code.
Has anyone seen this issue?
Thanks
Thanks
