No. The 1500 is a light duty truck. It is not designed to carry heavy loads typical of a gooseneck application. It is very much NOT a factory option. If you plan to use it, be very mindful of your payload rating (should be on the yellow sticker on your drivers B pillar and try your best not to exceed that number. Gooseneck towing usually puts 20-25% of the trailer weight on the pin. Assuming you have 1500 lbs of payload, that means that have a maximum gooseneck trailering ability of 6000-7500 lbs. When I say maximum, that means with zero passengers and zero additional weight in the truck.
