I didn't have any duct work with the Jump Seat - Quad Cab must not have that, so at least I didn't have to mess with any of that.
She's all done, pretty much. A few issues I need to sort out. The front two smaller bolts are not in, there was not any brass clips in those spots. I see where I can pull them from, but wasn't sure how to pull them without destroying them, so will research that and them move them. That's easy to get to.
I also ran into some issues with the 12v in the smaller cubby. The cable from the truck was no where near long enough to reach the plug, which I think I've read before - I didn't feel like splicing anything right now so thought I was being super clever and just pulled the 12v usb out of the lower panel that was removed. Snapped right in, and gave me some cable length - but for the life of me I could not get that connection to fit. They are the same "cross shape" style connector, but the cig lighter version must be slightly different that the USB version. So I left that alone and may eventually go the splice route I guess. The USB, SD Card etc in the top part of the console is working, so may not even bother. I just wanted this baby in lol
The Front mount bracket was no issue, just used 1" 3/8 bolts and fender washers - a stubby wrench on the back side made it quick and easy to tighten up. The rear bolted in no issues.
Actually, other than the wiring bits, when I took a break for the rain I didn't realize how close I was to being done. It all when together pretty quick from that point. Although if I would have stopped to spice wiring it would have taken longer. I also did the jack mount fix while I had the pass seat out.
I did get an airbag message first time I key'd everything back on, but I assume that was due to pass seat still be out/disconnected. Once I got it all back in the error went away.
This bright idea didn't pan out
Getting there...
Here's the clip I need to move for the two front screws...
Can't forget the blue LED for the upper glove box lol
Success (mostly)
I think the black top was the way to go for sure...
Oh yeah, my Husky rear doesn't quite fit now - I guess they have different version for jump seat vs console. Probably just needs a bit of trimming at the back of the console, it still fits everywhere else...
And these are the non-functional vents - I may replace that panel with a true quad cab style with no vents if I can find the right part number as mentioned a few posts up.
Dirty back panel, I cleaned it after the pic!
Ugh, the aftermath. Going out to dinner first, will clean up later hah!
And a large pile of spare parts now...
I'll be selling off that Jump Seat with Black Leather if anyone is interested. Also that Grey Upper Armrest as well...
