Joel Penkala
Greetings,
Have read a bunch of threads about lights flickering- primarily interior, dash, map lights, etc. I was just wondering if anyone's licence plate lights have done the same, and if so, the same fix applies. Sounds like most replace the bulbs. I have about 36k on the truck, and they are the factory lights so I am a bit suspicious that it's a cheap bulb or something along those lines. Have checked the initial connections by wiggling etc, and have not had an affect on the flicker. Have yet to crawl under and test w/ volt meter all the way back to the front of the truck, and seeing as to how its 4 degrees out here in NJ right now, w. snow on the ground I am not pumped to do so. Any help much appreciated. My thoughts were a bad ground, faulty wire, or the body control module?
-Joel
-Joel
