aggie77
I just picked up my truck yesterday - a 2016 1500 with a 5.7/8-spd and "dual exhaust". The latter is in quotes since the pipes come down from the manifolds into a Y-pipe to a single muffler which branches out to two pipes. My concern is the cross-over from the driver to the passenger side in the Y-pipe area. The crossover is literally 1" from the bottom of the tranny pan. The pan itself is composite, not metal. There is no heat shield between the pipe and the pan and there's a lot of heat, especially since I'll be towing a 5,500 lb RV around the country. I'm not particularly worried about the pan melting but I am worried about the excess heat reflected to the trans pan when pulling a trailer on highways that are in excess of 120 degrees in the summer around here. I'm probably going to get some header wrap to cover the exhaust pipe in the area close to the pan but was wondering what others may have found regarding transmission fluid temps when pulling a load in hot weather.
I did some searching on the forum before posting and didn't come up with anything relevant. Since this is my first post, please be civil.
