blackbetty14
- Oct 23, 2014
- 2,701
- 1,424
- Location
- CT
- 2024
- Hemi 5.7 VVT/Etorque
My new 18 Laramie with the premium 7" EVIC cluster I think is doing something weird. I can't remember exactly but I got the truck around 12/14 and if I remember correctly the oil temp gauge reading started at a much lower temp than it does now.
Its been winter here in NJ since I picked it up, snow already on the ground. If I recall even with my 14 express the oil temp reading on the EVIC started around 90*F right? I thought my new truck did as well, then one really cold day like 3*F ambient the oil gauge did something funny. It now (for the last week or so) will only start at 122*F as its base low reading. After a bit of driving it will not move from the 122*F starting point and then it will jump quickly from say 122 to 125/127/130/132/134 etc like it will change 2*F every sec or so which is not accurate. Till it reaches a stable temp like 140*F which is where it should be with a 180*F engine temp etc. Then the temps will increase correctly like 2*F every 15sec or so of driving. I feel like something happened or the sensor didn't like the cold and it lost the lower half of its temp range.
I dont like that its not reading below 122*F when my tranny temp can read as low as like 40*F. Im thinking the 122*F false oil temp could be affecting low temp engine running. I just want to know if this is something I should bring it to the dealer to take a look at. I just had it in for a mirror defect replacement.
Can someone verify there 7" EVIC cluster base oil temp reading? I'm talking like it sitting over night, to just see what it will read below 122*F, or am I just losing my mind.
