2018 powerwagon with new wheels/tires!
pwjouster
South Florida
have my stock 2018 powerwagon finally riding on some real rubber.
35x12.5/17 Load E Toyo RT
17 Method NV
running 45PSI Front and 35PSI Rear
Stock Suspension
Rub on the rear lower plastic liner the juts out near the bottom outside corners of the front wheel wells. about 50% to full to lock it rubs.
only on slight off camber/uneven turns or with passenger. no wear yet, and i didnt want to chop anything because my lift is only a couple months away. no body modification if possible!
you could not offroad without constant rubbing. at least i wouldnt
West Virginia
Sucks that it rubs. Its hard to believe it could. Mine appears to have so much space in the front wheel well. I have a feeling I will just stick with the stock duratracs.
Sdreeser
Maryland
6.4 hemi
Truck looks great!!!. I want to put 35's on my 2018 pw but keep the stock wheels with no lift. Do you know if they would rub on stock wheel?
Sdreeser
Maryland
6.4 hemi
Also what type of lift are you getting? I can' find any lift or leveling kit for the 2017-18 pw. Except from aev and that one is very expensive for only 1 inch of lift
pwjouster
pwjouster
South Florida
you may be ok with a 12.5 wide tire on the stock rims but i can not confirm. you may rub on sway bar or radius arm and not on the plastic wheel well.
im going to run a Thuren tuned King pintop shock kit. i couldnt care less about the actual amount of lift as im going for performance, not stance.
one of the top two most expensive kits for our trucks and as i have heard...the best kit for hemi specific tuning options geared towards your specific use.
Carli and Thuren have you covered.
Sdreeser
Maryland
6.4 hemi
Ok cool, thanks for the info. I will check them out
Nick@GotExhaust
Preferred Vendor
SC
Looks great. What offset are those wheels 0? Let me know if I can help you out with any Thuren products. We are a dealer for them as well
ramportin1
Sickest member here
Oregon
These new power wagons are some seriously bad A trucks. awesome man
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
I have 315/70/17 on my stock wheels and there’s no rubbing and they fit and look great.
pwjouster
pwjouster
South Florida
method only offers this bolt pattern with a 17x8.5 and 0/4.75"
i should be all set on my thuren hardware but i appreciate it!
i do need to address the elephant in the room.....exhaust and intake!
pwjouster
pwjouster
South Florida
you see it...you immediately need it...at least thats how i felt lol.
thank you and i absolutely agree! Dodge has brought the Powerwagon to the next level of brute nature and strength. All the while being crippled by computer and manufacturer interference with your ability to use it.
Nick@GotExhaust
Preferred Vendor
SC
Let me know when ready. We can get you hooked up!
Sent from my XT1650 using Tapatalk
forte
2017 Power wagon
Great looking truck!
I've never checked out the Method NVs wheels before but they look good with those tires. Can you post a closer picture of the wheels/tires. I really like those but ideally I wouldn't want any chrome accents on it.
Now I'm torn between these and AEV Katla wheels. I only ever see AEV products on Jeeps though, so not sure if they'd look out of place.
pwjouster
pwjouster
South Florida
you can replace the fake beadlock bolts with gold/zinc or black hardware i believe
astrayer1990
ANTIGO, WI
17 Method NV
Stock Suspension
View attachment 120196 View attachment 120197 View attachment 120198 View attachment 120199 View attachment 120200
Can you show us specifically where it rubbed? i want to run the same wheels on my 2018 PW. i already have 35's, but i dont want to lift at this point and i want to see what i have to modify to make the not rub
