285 75 18 or 295 70 18 on stock height 2500
King nothing
Central IL
Cummins
Will they fit? The 285 work out to about 35 inches tall and 10.5 wide while the 295 are 35 x 11
MADDOG
Out Exploring Arizona
Yup...I put 285/75x18's on my 07 MegaCab and the 2014 HD CC before I put the level kits on. No issues with rubbing at all.
firemancooter
New Melle, MO
2014 2500 Tradesman 4x4
35 13.50 18 on my CCSB 2500 no lift. Very minor rub on the trailing arm.
Sent from my VS985 4G using Tapatalk
stoney
Ontario
2015 | 2500 SLT CC
6.4L w/ 4:10
295/65R18 on mine, no issues and look soooo much better than the stock!
azeemtn
295 70 18 on my Megacab 4x4. No rub, no issues.
Fearfact
285/75r18 cooper at3 with stock steelies on my 16 ccsb work truck. Running a plow and towing heavy with zero issues
Odin
Arizona aka HELL
Hemi 6.4L
I've got 325/65/18 on mine. Had to trim some of the inner lower wheel well out and only rub at full lock in reverse. But I also have aftermarket wheels, not stock
Sent from my SM-G950U using Tapatalk
1500ram12
5.9L Cummins
35x12.5x17 on 17x8.5 w/+18 offset stock suspension, no rubbing
Cummins Dog
I just put 295/70/18s on my stock height 2500 on +1 offset wheels and I'm getting a very slight rubbing on the left front when I make a hard turn and hit a bump, like turning into a driveway. It just barely rubs but it bugs me so I'm getting a level done on the front Friday. Also, just a maybe, but I have a grille guard and winch mount on the front so maybe that pulls down the front end just a hair allowing the rubbing.
BrianJE
Cheney WA
Tiresize.com says a 295 / 75/ 18 is 34.8 x 11.2 x 18 and a 295 / 70 / 18 is 34.3 x 11.6 x 18
I run cooper AT3's in 295/70/18 stock height no level kit. I have no rubbing. Also I measured my tires and they are 34" tall. I am sure it varies by tire brand/type. do have after market rims. Not sure what offset.20180202_125442.jpg
K
King nothing
Central IL
Cummins
I run cooper AT3's in 295/70/18 stock height no level kit. I have no rubbing. Also I measured my tires and they are 34" tall. I am sure it varies by tire brand/type. do have after market rims. Not sure what offset.View attachment 121811
Looks great. I’m 99% decided that I’m going to run 285/75-18 on my stock chrome rims. I’d rather be a little taller and skinnier. I’m looking at Coopers as well. They seem to have good reviews and good tread life without the Toyo/Nitto price tag
COAinPaso
That’s definitely what I’m after next time I get tires. What is that level kit?
Just a spacer from rugged off-road, 1.75", and bilsteins.
Sent from my iPad using Tapatalk Pro
IdahoEagle
Idaho
6.4 Liter
I pondered this question for weeks, and was even told from virtually everyone I spoke with at Discount Tire that 285/75/18 wouldn't fit on my STOCK (no level or lift) 2019 Ram 2500 Tradesman. They told me I wouldn't be able to even get out of the parking lot due to how bad it would rub. Well, they were wrong. I did my research on this subject and I made my final decision to go with 285/75/18 with a wheel offset of +18. No rubbing anywhere whatsoever, on road OR off-road.
Sligo
295/70/18 had no issue on factory wheels. Slight rub on aftermarket wheels.
tazdawg
UTAH
2014 2500 Laramie
HEMI 6.4
285/75/18 on XD wheels, no lift runs great with Cooper XLT on my 14 2500 HD Laramie 4x4
JayLuke
SO CA
CTD 6.7L
The wheel offset is the limiting factor, stay close to stock and you should have any problems with bigger tires.
