2nd Gen LED dash light Change DIY
Discussion in '2nd Gen DIY' started by wermbang, Apr 16, 2011.
  1. ramthis9501
    ramthis9501 Senior Member
    22
    2,948
    23
    Jul 25, 2010
    Oklahoma
    Ram Year:
    2001
    Engine:
    5.2 V8
    Just put mine in and they barely dim if any
  2. wermbang
    wermbang Senior Member
    35
    9,707
    171
    Iowa
    Ram Year:
    2001 Off Road
    Engine:
    5.9L V8 Sport
    Yeah no dimming. I have read somewhere about something you can add but for me its not that bad at all.
    If you do red ones, its is much easier on your eyes too.
  3. Rogan68
    Rogan68 Senior Member
    545
    Aug 26, 2011
    Lancaster, TX / Winchester, VA
    Ram Year:
    2001
    Engine:
    5.9L CTD 24v 6 hole Bolt-action
    Yeah, thanks. Old like to do red it orange (like my BMW) the blues look great, but I can imagine my 43 ye old eyes trying to not catch a glare.
    per Tapatalk on my EVO
  4. SkRam
    SkRam Junior Member
    Jun 19, 2011
    Ram Year:
    1998
    Engine:
    5.9
    Do you know what part is needed to get the dimming working again? I am very critical and its bothering me lol.
    btw thanks for the right up. I ended up using different LEDs because the light wasnt even throughout the bezel. no need to yank out the metal pieces. all you have to do is remove the old twist locks and bulbs and put these in!
    WLED-xHP5-PC: LED T10 Wedge Base Bulb w/ Twist Lock Socket @superbrightleds
  5. the codes
    the codes Senior Member
    4,210
    112
    Jan 8, 2012
    Houston, Tx
    Ram Year:
    1998
    Engine:
    Magnum 5.2
    awessssommeeee! I'm about to order some stuff from them...mind as well throw those in the cart!
    Tapatalk Addict
  6. wermbang
    35
    9,707
    171
    Iowa
    Ram Year:
    2001 Off Road
    Engine:
    5.9L V8 Sport
    I don't know how to get them to dim. In my research I don't think its possible
  7. SkRam
    SkRam Junior Member
    Jun 19, 2011
    Ram Year:
    1998
    Engine:
    5.9
    Well I decided that the window switches needed to be done too. heres a pic of what it looks like done. I didnt take pictures of the process but its pretty straight forward.
    tools needed
    needlenose pliers
    soldering iron
    solder
    3mm LEDs Link
    some type of soldering remover
    -remove the switch from the door.
    -carefully remove the white bottom cover with a flathead.
    -locate the 3 bulbs on the drivers side and 2 on the passengers.
    -get some desoldering wick and remove as much solder as you can from the bulbs.
    -you might have to wiggle the wires loose.
    -I ended up taking needlenose pliers and pulling lightly as I heated up the solder to free them.
    -go to ur truck, plug the switch back in (no need to put it all back together) and touch the -leds on each side of the hole to find out what direction they go in.
    -then just slide the leds all the way through the hole and solder in. make sure not to use to much solder as the connections might touch each other.
    -make sure to test one more time before you but the wires down and put back together
    [​IMG]
    Ram digger likes this.
  8. Rogan68
    545
    Aug 26, 2011
    Ram Year:
    2001
    Engine:
    solder-suckers ftw
  9. wermbang
    35
    9,707
    171
    Iowa
    Ram Year:
    2001 Off Road
    Engine:
    5.9L V8 Sport
    thats cool. Wish I were good at soldering
  10. the codes
    4,210
    112
    Jan 8, 2012
    Houston, Tx
    Ram Year:
    1998
    Engine:
    Magnum 5.2
    thats cooool, damn I need to get to doing this.
Share This Page
