305/70R16 Or 285/75R16?
Discussion in 'Exterior' started by CountryBoy4598, Dec 7, 2015.
Sponsored By: BAK Factory Outlet
  1. CountryBoy4598
    CountryBoy4598 Member
    31
    Nov 28, 2015
    Vermont
    Ram Year:
    1994
    Engine:
    318
    Looking for a good 33" tire for my '94 1500 regular cab LB. I'll probably have some front coil springs from a Cummins and will probably add a leaf or two in the rear to make it level within the next few weeks and want to know which size may rub more than the other or none at all, I'm leaning toward the bigger meaner 305's but my wallet may want some 285's. Would like to see some pics of both to see how they look too, thanks
  2. bassslayer25
    bassslayer25 Senior Member
    2,033
    715
    Feb 7, 2014
    East, Kansas
    Ram Year:
    2000
    Engine:
    5.9 360 V8
    Remember the bigger you go the more power it will take to turn the tire. So you will lose a little get up if you go with the 305 vs the 285. I have 285's with a 2.5 inch lift and they are a perfect size. Factory tires were 245's so the closest you can stay to that size the better.
    Unless of course you want to regear then you could run 35's with 4.10 or 4.56 gears and be A ok.
  3. BBartow
    BBartow Senior Member
    5,759
    3,313
    Nov 18, 2013
    New Port Richey, Florida
    Ram Year:
    1995
    Engine:
    5.9L Magnum
    Same height, .8" width difference.
    If you're running factory wheels 285/75R16 is your only choice.
  4. MADDOG
    MADDOG Super Moderator Staff Member
    7,130
    1,880
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    305 may be a bit too wide for stock wheels if that is what you are runnin'.
  5. jsmith
    jsmith Senior Member
    272
    99
    Mar 8, 2015
    Ram Year:
    1999
    Engine:
    5.9
    I have 305/70/16s on the factory triblades.....
  6. BBartow
    5,759
    3,313
    Nov 18, 2013
    Ram Year:
    1995
    Engine:
    5.9L Magnum
    So you're running 12" tires on 7" wheels?
  7. jsmith
    272
    99
    Mar 8, 2015
    Ram Year:
    1999
    Engine:
    5.9
    Thought the triple spoke ones were 8" ? Either way yea bought it with 305s and no problems whatsoever. I've run 35x12.5s on my old Jeep on 7" rims too
  8. BBartow
    5,759
    3,313
    Nov 18, 2013
    Ram Year:
    1995
    Engine:
    5.9L Magnum
    Only stock 1500 wheels that were 8" were ore wheels.
    Oh you're that guy. We had this conversation before lol. On an off road toy you can, but wear will be bad on road.
  9. jsmith
    272
    99
    Mar 8, 2015
    Ram Year:
    1999
    Engine:
    5.9
    Lol don't remember but I do admit I'm starting to get up there. I have zero abnormal wear issues on the Ram, well other than Kumho tires wear down too fast but that's a whole different discussion
  10. CountryBoy4598
    31
    Nov 28, 2015
    Vermont
    Ram Year:
    1994
    Engine:
    318
    I would be running my stock wheels the chrome clad 5 spoke looking ones from '94. And I believe they're 7" wide. Anyone have pictures?
Share This Page
