318 plenum reinforcement kit
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
also depends how much you have to clean. I'm still cleaning mine 2 days later. I'm just replacing everything I can now. Don't wait too long or this will happen. I didn't have any trouble until last week and I wish I knew to check it sooner.
Good Gawd... that's just fugly... I thought mine was bad...
Badger
Bettendorf, IA
Is there anything else I should ne addressing when I do this? I'm going to also throw on a 180 thermostat but what else?
Georges98
Chicago
Im not sure about that 180 stat Badger. If you're not running a tuner, I think the factory 195 is better.
I did Valve Cover gaskets when I did mine, easy time to do it. Do a tuneup (Cap rotor plugs wires etc) Its all easy to get yourself into when you got er tore up. Get the little bypass hose under that bracketry there and do it too.
txbass06
NE Texas
5.9 Magnum
I haven't had any issues with my 180 tstat. And I agree with the cap, rotor, and bypass hose on the front of the intake. It's a lot of work to replace just that hose if it ever fails
Mopar1973Man
New Meadows, Idaho
As for the 180*F thermostat if your in cold country don't do it... I've been fighter to get heat in the truck as is now. The factory 195*F is much better and also should do better for MPG too.
Valve cover are a good suggestion... While its all apart just get the upper end sealed up.
If you get the gasket kit from RockAuto.com lie I did you end up with that little hose as part of the kit and a 180*F thermostat... Which now I regret installing the thermostart... Brrr... Cold!
Georges98
Chicago
Yeah, I made the 195 suggestion as I think Badger's weather and mine in Chicago are pretty close, and a 180 is probably just too cold for winter.
You cold also check out that write-up on the spark plug wire routing diagram for kicks when you get that point.
Kno
5.2L 318
Awesome post! I wish I would have found this BEFORE I started this project. I did get the gaskets done now im in the process of putting it all back together when I realized I have vacuum lines EVERYWHERE, and when i try to move them they start breaking...now I have no idea where they go. Can someone post a detailed picture or something?
Muddytazz
Salem, Or
2013 Ram 2500HD 4x4
Hemi baby
Ok, whats the little intake by-pass hose thing?
Hotroder383
Washington Mo
318 or 5.2 which ever you want
Intake bypass thing?? You talking about the EGR hose?? A pic might help =)
Muddytazz
Salem, Or
2013 Ram 2500HD 4x4
Hemi baby
Don't know what to even take a pic of to take one......its mentioned in this write-up but not shown. I'm trying to figure out what it is lol
txbass06
NE Texas
5.9 Magnum
I think you're talking about the by-pass hose that runs from the front of the intake to the top of the water pump. About a 4" hose with a 90 degree bend in it?
Muddytazz
Salem, Or
2013 Ram 2500HD 4x4
Hemi baby
Picture would be great so I can see what what is the purpose?
2000DirtyDodge
Navarre FL/Hurlburt FLD, FL
2000 1500 Club Cab SLT
5.9/Auto/2WD
This looks pretty dang intense. My ram is pinging and I have oil in my intake. guess I'm next to do it.
Hell while this hole thing is apart might as well do headers, tune up, Cam, rockers, and whatever else....
Micchi
West Lawn, PA
5.2L
Any reason not to use gasket sealer? Only asking cuz my dad thinks I should put some on just in case. What's the harm if I do?
