35's won't balance
Z mann R2
So my new lift n tires n wheels looks great but they seemed to have come in unbalanced. So custom offsets paid me to take it somewhere for a balance and I did. The shop (who is a specialty shop for lifts and tires) balanced all 4 and I still feel wobble on the highway. It didn't feel this way before I installed everything so it can't be the bearings or anything like that.
Could it be the way theyre mounting onto the lugs? How about the locking lug nuts which appear much heavier than the regular lugs?
Also, what are those little rings that are on the studs up against the hub? there's 2 per hub, some studs don't have them. Seem like it would keep the wheel from sitting flush against the hub
Salsa
Montana
I was just told this past Friday from a friend that ran a tire service dept that those clips should not be on wheels for Ram trucks. I told him I bought Moto Metal MO970's and he said to check and make sure they are not on there. They create problems and one is over time some of the aluminum wheels crack. He did tell me that some tire shops leave them on and don't know any better. I bought mine from CARiD and they did not come with the wheels. My friend has the same MO970 wheels as mine. I just read some more info about my truck & it mentioned to check the wheels for the clips and they shouldn't be on for my Truck.
Jarhead57
Santa Barbara, Ca
2015 4x4 CC Bighorn
Those are "stud clips" used to hold things together during the build of the truck, not needed when wheels are installed. It's highly recommended in everything I have read to remove those before installing any aftermarket wheels as they can cause vibrations. First thing I did was to remove those from my truck, even though I still have stock wheels.
JB1
Houston, Texas
Remove those star washers but also you probably need hubcentric spacers
MADDOG
Not RamForum Staff
Yup, take the washers off and, if you still have a balance issue, try a "road force" balance vs. a spin or static balance.
