3rd Gen Technical Service Bulletins
Discussion in 'Tech Info' started by lilfroger, Nov 10, 2010.
Thread Status:
Not open for further replies.
  1. lilfroger
    lilfroger Senior Member
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 14-001-10 : Dtc p0251
    Service bulletin #: 14-001-10
    replacement sb#:
    Nhtsa item #: 10033546
    date: 20100202
    failing component: 092100 fuel system, other: Delivery:fuel pump
    make: Dodge
    model: Ram
    year: 2003, 2004, 2005, 2006, 2007
    date created: 20100823
    description of summary: Dodge: Electronic fuel control actuator (fca) available for service/new diagnostics available for dtc p0251. Engine surges at idle or mil illumination. Further investigation may identify dtc p0251-cp3 pump regulator control-diesel. If p0251 is present, follow the diagnostics in this sb. If other dtc's are present, repair as necessary before proceeding further. Model ram truck. *pe
  2. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    TSB-19-002-10: Steering Wander
    Service bulletin #: 19-002-10
    replacement sb#:
    Nhtsa item #: 10033671
    date: 20100123
    failing component: 010000 steering
    make: Dodge
    model: Ram 4500, 5500
    year: 2008
    date created: 20100903
    description of summary: Dodge: Steering wander. Involves selecting the proper repair procedure based upon vehicle build dates and then aligning the vehicle with revised specs. *pe
Thread Status:
Share This Page
