3rd Gen Technical Service Bulletins
Discussion in 'Tech Info' started by lilfroger, Nov 10, 2010.
Thread Status:
Not open for further replies.
  1. lilfroger
    lilfroger Senior Member
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 2022: Torque converter drain back valve
    Service bulletin #: 2022
    replacement sb#:
    Nhtsa item #: 10000444
    date: 20021126
    failing component: 103700 power train:automatic transmission:torque converter
    make: Dodge
    model: Ram
    year: 2003
    date created: 20030227
    description of summary: The transmission may overheat due to a restriction in the torque converter drain back valve. *tt
  2. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1400502: Fuel filter/water separator drain
    Service bulletin #: 1400502
    replacement sb#:
    Nhtsa item #: 10000447
    date: 20021108
    failing component: 070000 fuel system, gasoline
    make: Dodge
    model: Ram pickup
    year: 2003
    description of summary: Fuel filter/water separator drain valve restriction. *tt
  3. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1803502: Code p2181 - cooling system performance
    Service bulletin #: 1803502
    replacement sb#:
    Nhtsa item #: 10000449
    date: 20021129
    failing component: 061000 engine and engine cooling:engine
    make: Dodge
    model: Ram pickup
    year: 2003
    description of summary: Engine throttle control light illumination and / or malfunction indicator light illumination with diagnostic trouble code p2181 - cooling system performance. *tt
  4. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 2024: Sticking pressure sensor transducer
    Service bulletin #: 2024
    replacement sb#:
    Nhtsa item #: 10000620
    date: 20021111
    failing component: 103000 power train:automatic transmission
    make: Dodge
    model: Ram
    year: 2003
    date created: 20030325
    description of summary: Harsh shifts due to a sticking pressure sensor transducer. *tt
  5. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 2026: Torque converter drain back valve
    Service bulletin #: 2026
    replacement sb#:
    Nhtsa item #: 10000830
    date: 20021220
    make: Dodge
    model: Ram
    year: 2003
    date created: 20030401
  6. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 33: Torque converter drain back valve
    Service bulletin #: 33
    replacement sb#: 222
    nhtsa item #: 10000834
    date: 20021201
    make: Dodge
    model: Ram pickup
    year: 2003
    description of summary: Customer satisfaction notification - torque converter drain back valve. *tt
  7. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1: 3/8" torque converter drain back valve
    replacement sb#:
    Nhtsa item #: 10000913
    date: 20030101
    make: Dodge
    model: Ram pickup
    year: 2003
    date created: 20030403
    description of summary: Customer satisfaction notification - 3/8" torque converter drain back valve. *tt
  8. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 02026a: Restriction in the torque converter drain back valve
    Service bulletin #: 02026a
    replacement sb#:
    Nhtsa item #: 10000914
    date: 20030116
    make: Dodge
    model: Ram
    year: 2003
    description of summary: The transmission may overheat due to a restriction in the torque converter drain back valve and may cause damage to the transmission. *tt
  9. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1800503: Transmission shift/speed control improvements
    Service bulletin #: 1800503
    replacement sb#:
    Nhtsa item #: 10001176
    date: 20030307
    failing component: 180000 vehicle speed control
    make: Dodge
    model: Ram pickup
    year: 2003
    date created: 20030417
    description of summary: Transmission shift/speed control improvements. *jb
  10. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 800703: Accessory drive belt squeal
    Service bulletin #: 800703
    replacement sb#:
    Nhtsa item #: 10001518
    date: 20030404
    failing component: 061110 engine and engine cooling:engine:gasoline:belts and associated pulleys
    make: Dodge
    model: Ram
    year: 2003
    date created: 20030605
    description of summary: Replacement of the alternator support bracket for accessory drive belt squeal. *tt
Thread Status:
Share This Page
