3rd Gen Technical Service Bulletins
Discussion in 'Tech Info' started by lilfroger, Nov 10, 2010.
Thread Status:
Not open for further replies.
  1. lilfroger
    lilfroger Senior Member
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1801403: Erroneous diagnostic trouble codes (dtc) p0300 - p0309
    Service bulletin #: 1801403
    replacement sb#:
    Nhtsa item #: 10001523
    date: 20030404
    failing component: 110000 electrical system
    make: Dodge
    model: Ram
    year: 2003
    date created: 20030605
    description of summary: Malfunction indicator lamp (mil) illumination, erroneous diagnostic trouble codes (dtc) p0300 - p0309. *tt
  2. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1801503: No shift out of third gear condition
    Service bulletin #: 1801503
    replacement sb#:
    Nhtsa item #: 10001524
    date: 20030404
    failing component: 103000 power train:automatic transmission
    make: Dodge
    model: Ram
    year: 2003
    description of summary: Powertrain control module (pcm) shift quality improvements for a no shift out of third gear condition. *tt
  3. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 3010: Scored 3.7l engine crankshaft
    Service bulletin #: 3010
    replacement sb#:
    Nhtsa item #: 10001533
    date: 20030424
    failing component: 061000 engine and engine cooling:engine
    make: Dodge
    model: Ram
    year: 2003
    date created: 20030606
    description of summary: Scored 3.7l engine crankshaft. *tt
  4. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 801903: Lamp out indicator with aftermarket pick up box installation
    Service bulletin #: 801903
    replacement sb#:
    Nhtsa item #: 10002039
    date: 20030620
    make: Dodge
    model: Ram
    year: 2003
    date created: 20030812
    description of summary: Lamp out indicator with aftermarket pick up box installation. *tt
  5. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 2301603: Buzzing or vibrating sound
    Service bulletin #: 2301603
    replacement sb#:
    Nhtsa item #: 10002050
    date: 20030613
    failing component: 162000 structure:body
    make: Dodge
    model: Ram
    year: 2003
    description of summary: Buzzing or vibrating sound coming from the front of the vehicle. *tt
  6. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    TSB 2301803: HEATER A/C BLOWER Noise
    Service bulletin #: 2301803
    replacement sb#:
    Nhtsa item #: 10002052
    date: 20030613
    make: Dodge
    model: Ram
    year: 2003
    description of summary: Whistling sound may be present coming from the front of the instrument panel near the bottom of the windshield when the heater a/c blower is on. *tt
  7. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 2400403: Defrost door inoperative
    Service bulletin #: 2400403
    replacement sb#:
    Nhtsa item #: 10002053
    date: 20030613
    failing component: 353600 equipment:electrical:air conditioner
    make: Dodge
    model: Ram
    year: 2003
    description of summary: Defrost door inoperative. *tt
  8. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1800503a: Transmission shift/speed control improvements
    Service bulletin #: 1800503a
    replacement sb#: 1800503
    nhtsa item #: 10002190
    date: 20030425
    failing component: 180000 vehicle speed control
    make: Dodge
    model: Ram pickup
    year: 2003
    date created: 20030815
    description of summary: Transmission shift/speed control improvements/possible malfunction indicator lamp illumination. *tt
  9. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1801303: (etc) light illumination and/or poor idle quality
    Service bulletin #: 1801303
    replacement sb#: 1803502
    nhtsa item #: 10002286
    date: 20030328
    make: Dodge
    model: Ram
    year: 2003
    date created: 20030820
    description of summary: Malfunction indicator lamp and/or engine throttle control (etc) light illumination, diagnostic trouble codes (dtcs), and/or poor idle quality. *tt
  10. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 800403: Erroneous indicator lamps
    Service bulletin #: 800403
    replacement sb#:
    Nhtsa item #: 10002292
    date: 20030314
    make: Dodge
    model: Ram
    year: 2003
    description of summary: Electro mechanical instrument cluster - erroneous indicator lamps. *tt
Thread Status:
Share This Page
